www.ColoradoClassicBroncos.com - View topic - project viperwolfe is starting
It is currently Sun Nov 24, 2024 9:42 pm
Reply to topic  [ 550 posts ]  Go to page Previous  1 ... 15, 16, 17, 18, 19
Post Re: project viperwolfe is starting
The shroud did help at low speed and idle in the triple digits. I did get some temp creep at high speed in those temps though. At cooler temps the engine runs within a couple degrees of the thermostat temp (193-195). Over 95 degrees would make creep to 203 after 10 miles on the highway at 70 mph. I know it doesn't sound terrible but this is on flat ground. So I did some research and found a replacement explorer radiator that had a 1/2" thicker core. Still 2 rows of tubes but each 1/4" wider. Total cost $118 at Summit. Now I have to wait for it to get hot again so I can put it to the test.20160607_175543.jpg
Tue Jun 07, 2016 9:54 pm
If it makes a difference I'll need a part # please.
Wed Jun 08, 2016 4:55 am
Wed Jun 08, 2016 11:34 am
Watching with much interest.
I'm going to put the shroud on mine and see how it does with the summer temps arriving in CO.
I'm thinking I may have to change out my Bronco radiator for your set up, especially if I now have to install air conditioner condenser in front of radiator.
Will be curious about trans temps too as I currently run mine through an auxiliary cooler. Ousted in front of radiator.
Fri Jun 10, 2016 6:14 pm
I decided to plug some holes around the radiator while I was at it.
Fri Jun 10, 2016 8:36 pm
Sun Jun 19, 2016 4:13 pm
Sun Jun 19, 2016 7:09 pm
Sweet, thanks. What pump are you running?
Sun Jun 19, 2016 7:10 pm
96 explorer pump
Sun Jun 19, 2016 7:18 pm
Much appreciated.
Sun Jun 19, 2016 7:58 pm
Users browsing this forum: No registered users and 74 guests
33,015,689 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
