Register •
FAQ
• Login
It is currently Sun Nov 24, 2024 5:34 pm
[ 4 posts ] |
Custom Safari top
My plan is to make a custom safari top this summer. Actually, have my upholstery lady do it for me by my design. I am looking for ideas on how to best execute this. Already have the windshield riser, so I am just trying to figure out how best to attach this top in more than just the two straps off the back. I was thinking velcro around the roll cage bars just in front of the "B" pillar and some side to side.
What are other designs I should consider?
Wed Mar 09, 2011 5:52 pm |
Re: Custom Safari top
My family cage has some strange angles an the back that will not work with normal bikini tops. I am thinking velcro as well. In reading the specs on the BC Bronco Can Back - it states that the Top Gun material is better than Sunbrella so I am going to use Top Gun on my Bikini. The Top Gun is 62" wide vs. 60" and available in more colors. I think 62" is perfect fit.
Wed Mar 09, 2011 8:20 pm |
Huh, well being that bronco is white, I was just going to go with Black. Probably would in any case, although grey wouldn't retain the heat. I will have to look at BC's site and check that out. I had not heard of the top gun stuff. Was just thinking she'd use the same marine material she's used for everything else she's done for me. Is the Top Gun stuff heavy or lighter weight? $2 for a sample card might be worth a look: http://www.yourautotrim.com/topgun.htmlJ.D.
Wed Mar 09, 2011 8:27 pm |
GMAN
I made my bikini top out of 60" Sunbrella because I liked the grey ans black patterned material. I attached it to my riser from my soft top, sewed welting in the front to slide in the track, hemmed the sides to fit the family cage and sewed two straps on the back. I did put padding on the top cage bars so the top would conform and fit tighter.... Good at 80 MPH minimal flap if any. I have seen the Top Gun material and it is also very nice. Keystone located at Missippi and Santa Fe has tons of material samples to look at including the Top Gun and also Aquamarine. If you want to see my top I can bring it to the CCB Breakfast.
_________________ GMAN 70 Roadster 347 burnt orange
Thu Mar 10, 2011 1:20 pm |
[ 4 posts ] |
Users browsing this forum: No registered users and 83 guests |
