www.ColoradoClassicBroncos.com - View topic - windshield stiffner/brace
It is currently Mon Nov 25, 2024 1:28 am
Reply to topic  [ 14 posts ]
Post windshield stiffner/brace
I need some advice. I have searched and not found what I am looking for. What are you using if you do not have a full cage and have the hard top off to stiffen up your windshield. I have found a couple of products (http://www.bcbroncos.com/store/product_ ... ts_id=2067), but they are kind of pricey. Your ideas and help are greatly apperciated. Jayson
74, MONEY EATER
Sat Aug 06, 2011 8:38 am
Post Re: windshield stiffner/brace
I guess I never really worried about it flexing much, but I have doors w/window frames and run a soft-top (which provides a small amount of pressure on the frame) most of the time. When I put a full cage in I'll probably run some small anchors just to tie it in. What year is your rig, are you running w/out door window frames and are you currently experiencing any significant flex? The products you've linked to are the only thing like that I've seen, they seem reasonable. You could try to make something yourself, just make sure it isn't too rigid since the Bronco body flexes under normal off road conditions.
Sat Aug 06, 2011 3:18 pm
You know you could make some metal braces yourself fairly cheap if you have your rear roll bar. I would get some flat metal stock and make some tabs for each end and fit it all up. If that makes any sense?
Sat Aug 06, 2011 4:51 pm
I have a 74 with the original bar in it. I will have my soft top inplace shortly. I have thought about using flat stock and was wondering what everyone else was using without a full cage. Thanks for the reply. Jayson
74, MONEY EATER
Sat Aug 06, 2011 5:06 pm
Hopefully Cortez will post up his solution. Hint - he used heims.
Sun Aug 07, 2011 1:04 am
Try these from Wildhorses an August Special...Plus they are $20 less!
http://www.wildhorses4x4.com/product/Wi ... Bars_Cages
74 Ranger
65 Fastback
Sun Aug 07, 2011 4:32 pm
I only have the bar behind the seat and not a full cage. Jayson
74, MONEY EATER
Sun Aug 07, 2011 5:16 pm
Sorry, I mis read your original post! banghead
74 Ranger
65 Fastback
Mon Aug 08, 2011 9:36 am
No problem pony. I think I have a solution and will post up my "southern enginered solution" once I work it out on wensday. Jayson
74, MONEY EATER
Mon Aug 08, 2011 10:42 am
VENDOR
VENDOR
I made some out of 1/2 in square stock, welded nuts on the ends and use heim joints one RH threaded one LFT hand on each. I also welded some tabs on the roll bar. I have the standard 4pt. roll bar. I still need to weld some tabs to my windshield riser but it's aluminum and I can't tig weld yet. My hard top is still on so I'm in no big hurry! here are some pictures.photo.jpgphoto-1.jpg
Fri Aug 12, 2011 9:32 pm
Profile WWW
Friday - that is better than anything from the part stores. I haven't seen Cortez's yet, but I am thinking it is very similar.
Fri Aug 12, 2011 10:01 pm
Those turned out nice, I see a new product in your future.
Sat Aug 13, 2011 10:25 am
Friday, those look nice.
I wound up using a couple of channel braces I had from an old toneau cover. I cut them down to size and drilled a hole in one end and cut the sides off about 3 inches. I then took a piece of scrap pipe with some round in it and welded a 3 inch tab on it with holes drilled in it. I attached the pipe piece to the top bar with clamps. So far it has worked okay. I still have some fine tunning to do. I will post up pictures once I the wife lets me have the camera. Jayson
74, MONEY EATER
Sat Aug 13, 2011 8:07 pm
VENDOR
VENDOR
Thanks for the compliments! Honestly, I wish they were on the bronco doing their job.
Sat Aug 13, 2011 9:26 pm
Profile WWW
Users browsing this forum: No registered users and 60 guests
33,021,279 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
