[phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4794: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4796: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4797: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4798: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) www.ColoradoClassicBroncos.com - View topic - good weld penatration?s
So I'm practicing on 1.5 tube and I've got good blue discolor on the outside and a blue ring on the inside tube. Is that hot enough? Also I've heard to drop your wire size to .024-.025 to slow down and get more heat.. thoughts ?
Users browsing this forum: No registered users and 82 guests
