www.ColoradoClassicBroncos.com - View topic - Anyone have a smog pump for a 302?
It is currently Mon Nov 25, 2024 9:55 pm
Reply to topic  [ 9 posts ]
Post Anyone have a smog pump for a 302?
So, i don't know how i overlooked this, however i failed to notice i was missing my smog pump... so need to get that on there as its the only thing I failed when I took the bronco in today for emissions testing.. guy was cool about it and he just said put one on, hook up the belt and bring it back and I will sign off..
i have 10 days to get back there, I plan on just going to the junk yard and pulling one but thought I would hit up you locals to see if anyone wants to free up some garage space ;)
Wed Nov 09, 2011 3:22 pm
Post Re: Anyone have a smog pump for a 302?
I have one, w/ a v- belt pully on it...
Wed Nov 09, 2011 9:02 pm
great, is there anyway i could borrow, buy, barter, beg for it? I should just be able to get a new longer vbelt for the alt side and run it correct?
Wed Nov 09, 2011 9:48 pm
yes, longer belt an good to go, I will pm you my number
Wed Nov 09, 2011 10:51 pm
awesome gave you a call and left a message. thanks
Thu Nov 10, 2011 12:14 pm
one of these?
http://www.youtube.com/watch?v=Qp04J6Fzd6c
only after I work at Gregs and had Santiagos all morning. laughing2
Thu Nov 10, 2011 7:54 pm
Dumb question; How was the 76 302 SMOG pump ported ( back of the head or through the exhaust manifold)? I got stationed in the evil CA and can't get my pig registered. I have a non-CA 1976 302 Bronco. I've recently changed the intake manifold to an Edelbrock w/EGR spacer. I pulled a 2bbl carb and SMOG pump from a 78 351 Ranchero. I believe all I need at this point is to run the pump's air. The back of the heads appear to be capped off and my exhaust manifold seems stock (without ports). I'm clueless. Everything I can find on SMOG show's me how to rid myself of this crap, or looks nothing close to under my hood, so any help you provide would help. Thanks - Paul
Sun Jan 27, 2013 11:22 pm
The 76 had air ports in each head on either side, then a vacuum solenoid hooked up between the smog pump and the air injection holes. The driver side was on the rear near the back of the exhaust manifold and the passenge side was at the front near the exhaust manifold, both locations on the head itself. The later year 302's had the emission ports on the rear of the heads... depending on what year engine you have and what california requires you might have to junkyard dive to get all the pieces.. there were quite a few things that make up the emissions on these. I will try to find a picture of everything you need for a 76.
I plumped mine from the smog pump to a one way valve right before the cat and passed. But I know california requires basically stock setup... or think it does.
Mon Jan 28, 2013 9:57 am
here are a few links that might help.. i think you might want to talk to a refree (i think thats what they are called) to make sure what you have so your not guessing. Also I would hook up with the california bronco group as they will have better solutions then we might out here in the colorado...
another
Mon Jan 28, 2013 10:02 am
Users browsing this forum: No registered users and 94 guests
33,100,528 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
