www.ColoradoClassicBroncos.com - View topic - Death Wobble!
It is currently Sun Nov 24, 2024 10:00 am
Reply to topic  [ 6 posts ]
 Death Wobble!
Post Death Wobble!
Help -
Driving the 74 Bronco on Saturday and expereinced a wobble like none I have ever experienced before.
I was heading east bound on C-470 exiting to Northbound I-25 and hit one of the seams in the bridge while turning at aproximately 55 mph or so. This threw the bronco into a wobble that can only be described as being inside an unballenced washer.
At my earliest opurtunity I pulled over and checked everything, nothing loose that I could find so I drove on and had no more problems. In talking to my 16 yr old who is driving it on occasion, he has had it happen to him as well.
Any ideas, I want to get this fixed asap.
Thanks,
Greg
Mon Nov 22, 2010 10:17 am
Post Re: Death Wobble!
It's pretty common on EBs. Usually associated with front end bushings being shot. Take a look at the track bar bushing, if you have a track bar bracket, make sure it is welded on correctly and make sure alignment is good. Tires can also cause the problem, but probably, the worn bushings is going to be your issue. Especially since you guys just bought the rig...right? It is pretty easy to take care of and if the bushings are fairly new, tires new, etc. check your steering stabilizer if you have one. A worn out stabilizer will magnify the issue, where a good one will help out with it to a certain degree.
Mon Nov 22, 2010 10:24 am
This issue has been talked about often with these trucks on CB.com, all the above are good things to check, I'll add that you'll want to check the ball joints and take it to get the alignment checked. Toe in is easy to correct yourself, camber isn't too bad either as long as the ball joints are good (napa sells shims to correct this), then finally the caster, which requires a different set of radius arm bushings to correct on a lifted rig.
Mon Nov 22, 2010 2:00 pm
I'm not discounting your experience and the need to check out your front end............
But I take that I25 on-ramp frequently and even my brand new vehicles jump half a lane on that expansion joint
Mon Nov 22, 2010 4:57 pm
Yeah, I take it all the time too, and I actually take it a little to fast quite often just to have the truck jump over - but this was something far FAR greater, the whole Bronco started shaking like an unbalanced washing machine and did not stop until I was doing less than 30mph and pulled over (I was in the meadian pulling onto I25 by the time it stopped). Quite scary.
I will be checking the suspension and steering tomorrow (the boys are off school so I can take the afternoon off to spend some time turning wrenches with them...
New windshield, washer solvent pump, pull the rear seat and now, up on stands and check the front end.
Tue Nov 23, 2010 11:26 am
Wed Nov 24, 2010 10:22 am
Users browsing this forum: No registered users and 29 guests
32,996,436 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
