www.ColoradoClassicBroncos.com - View topic - Viper's little elves...
It is currently Mon Nov 25, 2024 1:56 pm
Reply to topic  [ 23 posts ]
Post Viper's little elves...
have been busy in the garage.
Wed Jan 04, 2012 7:27 pm
Post Re: Viper's little elves...
ooohh lala! I wish one of those would fit my F250. Heck one for my Bronco would be nice too.
Wed Jan 04, 2012 7:32 pm
That why you didnt come snow wheelin with us?
Wed Jan 04, 2012 7:58 pm
Is mine the one on the right or the one on the left? I guess I better get a column together! And a twin stick, and a...... I got work to do.
Wed Jan 04, 2012 8:42 pm
Your's is on the right Jeremy, Kinder's is on the left. There pretty much identical twins though.
I didn't go on the run because I have a problem with my rear locker. It seems to have a air leak and I think it's the internal seal. I'll have to pull it out to replace it.
Wed Jan 04, 2012 9:09 pm
Nothin' better than a ViperBuilt C4 - way better than even Ford built them.
Wed Jan 04, 2012 9:57 pm
Wed Jan 04, 2012 11:43 pm
Thu Jan 05, 2012 9:32 am
Bah, humbug. A doctor can't do anything I can't do for myself.
Thu Jan 05, 2012 10:07 am
WOW!!! Really looks like you do an AMAZING job Viperwolf! I can't WAIT to get mine dropped off with you! Saturday afternoon -- I'll be back from my second job, no football, no wife, no kids -- just under the 75BDE pulling that bad boy out of there!
Thu Jan 05, 2012 1:30 pm
Speaking of dropping off transmissions... i have mine "cleaned" and ready to go.. including the TC as well.. when and can i drop er off?
Thu Jan 05, 2012 5:56 pm
Thu Jan 05, 2012 6:22 pm
Thu Jan 05, 2012 9:42 pm
Stock converter so it's probably about 1500-1600 rpm stall. Unboosted disks are a bear to hold with an auto trans, especially in low range. A higher stall speed probably won't make any difference at idle speeds. There is no adjustment possible.
The valve body needs to come out to remove the shift kit. I have stock parts to put back in. There are a couple adjustments for this though. If you want a softer shift you can swap out the rod under the modulator for a shorter one and there is a screw adjustment on the modulator also.
I have spare trans/adapter gaskets.
Fri Jan 06, 2012 11:41 am
Sat Jan 07, 2012 6:18 pm
Locally you can try.
branting industries in arvada 303-425-9004
A lot of the Local USP heads up racers use them.
Sun Jan 08, 2012 12:20 am
Tue Jan 10, 2012 7:51 am
Good time of year to be in the snow shovelling business too.
Tue Jan 10, 2012 11:12 am
Tue Jan 10, 2012 11:13 am
2-4 inches expected tomorrow.
Tue Jan 10, 2012 11:15 am
Tue Jan 10, 2012 4:35 pm
...I hope we get 4-6" every week!
Thu Jan 19, 2012 10:35 pm
So thanks to the exceptional work of Viperwolf1, I've got a better than new C4 transmission and transfer case sitting in my garage! I can't wait to get them back in the 75DBE. Thaanks again Viperwolf -- awesome job.
Tue Apr 17, 2012 6:08 pm
Users browsing this forum: No registered users and 104 guests
33,051,788 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
