www.ColoradoClassicBroncos.com - View topic - winch mounting questions
It is currently Mon Nov 25, 2024 11:28 am
Reply to topic  [ 3 posts ]
Post winch mounting questions
Ok so I'm building a bumper right now and I'm curious about the winch mount. I have a bracket to hold the fairlead but the bolts are like 7/16 or 3/8. Seems under sized to me. It the winch all shear load ?
Thu Feb 16, 2012 9:48 pm
Post Re: winch mounting questions
Is it bottom mounted? If so then a fine thread will have more sectional area to the bolt hence a stronger connection for shear. Plus you know then you might want to go grade 8. I used to use a socket head if i wanted the high strength because they have a higher tensile strength than a conventional bolt unless you go grade 8.
Fri Feb 17, 2012 5:23 am
The fairleads don't generally see too much force. But go grade 8 if you're worried.
Fri Feb 17, 2012 12:05 pm
Users browsing this forum: No registered users and 84 guests
33,038,580 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
