www.ColoradoClassicBroncos.com - View topic - 5.0 has no go
It is currently Mon Nov 25, 2024 3:59 pm
Reply to topic  [ 9 posts ]
 5.0 has no go
Post 5.0 has no go
I just compression tested my engine #1-70,2-70,3-80,4-90,5-90,6-95,7-90,8-95.the spark plugs looked good and i have a msd ignition in it,but it has no power.any suggestions?
Tue May 01, 2012 12:10 pm
Post Re: 5.0 has no go
That is very low. Either the timing chain has stretched and jumped a tooth or that motor is just plain worn out.
Tue May 01, 2012 1:12 pm
Did you open the throttle up all the way when you performed the compression test? I have seen numbers like that when someone forgot to open it all the way up.
Tue May 01, 2012 2:01 pm
I didn't know that I'll try it again
Tue May 01, 2012 3:01 pm
just did it with the throttle open and they went up twenty.so Number one is 90,2-90,3-100,4-110,5-110,6-115,7-110,8-115
Tue May 01, 2012 7:12 pm
Check to see if you have spark, use instructions under "Magnetic Pick Up Trigger":
http://www.msdignition.com/page.aspx?id=3206
Tue May 01, 2012 8:06 pm
Just did the msd test and its working.
Wed May 02, 2012 1:28 pm
Those comp numbers are still pretty low. Do you know the history behind the motor? Miles, cam, previous repair work done.
Wed May 02, 2012 3:07 pm
no nothing in fact he told me it was a 351 lol
Thu May 03, 2012 11:14 am
Users browsing this forum: No registered users and 96 guests
33,068,126 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
