www.ColoradoClassicBroncos.com - View topic - Torch
It is currently Mon Nov 25, 2024 3:37 pm
Reply to topic  [ 3 posts ]
 Torch
Post Torch
I'm thinking about picking up a torch to use for bending shifters, cutting steel plate for a bumper, etc and have a few questions. Any reason buying used is a bad idea? I'm pretty sure I won't be able to afford a new one. How about the small Porta A Torches? Other than capacity, how well do these work? For those of you have have torches, how much use do you wind up using them?
Thu May 31, 2012 10:50 pm
Post Re: Torch
Check out Tool King, now that your so close, before buying a new set up. I have been looking at options as well. The cylinders are the tricky part, lease or buy?? depends on just how much you will really use it. I got a price on all new everything from cylinders to the cart and it was near $900. If you can find a used set up you would be better off, if anything buy new hoses. I ended up getting my dads old stuff.
BTW- you can always borrow mine.
Fri Jun 01, 2012 9:51 am
Post Re: Torch
Thanks, borrowing yours may wind up being the best option. I really appreciate the offer. I'm not 100% sure that the amount of use it'll see justifies the $$$.
Fri Jun 01, 2012 2:19 pm
Users browsing this forum: Google [Bot] and 97 guests
33,062,667 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
