It is currently Mon Nov 25, 2024 7:37 pm
[ 4 posts ] |
Recommendation needed: need to get some heads cleaned up
As my 351 build/install is probably a year off, I was thinking about having my GT40s cleaned up so I can run them on my 302. Anyone have a good recommendation for a shop in the Springs to do the work?
Sun Jul 15, 2012 2:12 pm |
Colorado75bronc
Rocky mountain machine, best ford guy in town other than Leonard vasholtz, call Stan over at rocky mountain, tell him my dad rec'd you; his number is : (719) 591-7915, he's located behind al Serra Chevy off of south academy and bijou area
Sun Jul 15, 2012 3:29 pm |
Thanks Corey. That's the name I was trying to remember.
Sun Jul 15, 2012 6:21 pm |
pilosopher
Joined: Thu Nov 17, 2011 8:32 am Posts: 39 Location: Palmer Lake, co
Re: Recommendation needed: need to get some heads cleaned up
Ive had lots of luck with Lees Automotive Machine shop. Its on the south west side of Academy and Platte
Mon Aug 27, 2012 3:33 pm |
[ 4 posts ] |
Users browsing this forum: No registered users and 117 guests |
