www.ColoradoClassicBroncos.com - View topic - Anyone have an Astro Hydroboost Output Rod?
It is currently Mon Nov 25, 2024 8:04 pm
Reply to topic  [ 22 posts ]
Post Anyone have an Astro Hydroboost Output Rod?
Found the reason why my brake pedal is rock hard.....neither the booster, nor the master cylinder came with an output rod as shown in this pic. Local parts shops don't seem to have them. Anyone have an extra? Thanks.
Thu May 02, 2013 10:20 am
Post Re: Anyone have an Astro Hydroboost Output Rod?
Another view....
Thu May 02, 2013 10:34 am
Pretty sure I have one rolling around in the floor of the 72 somewhere. I'll look and see if I can find it.
Thu May 02, 2013 11:16 am
Not sure if all of the output rods have it, but the Lincoln rod I picked up had an adjustable portion on the end. This allowed you to extend or reduce the overall length of the rod. Handy when you are using a different master cylinder where the depth of the input on the master cylinder might be different than the original application.
Thu May 02, 2013 11:18 am
Cool, let me know. I think there are 3 parts, the rod, spring, and retainer that I need.
Thu May 02, 2013 11:20 am
I called around to every shop and even a Chevy parts shop at the dealer. He told me this part was never even manufactured as a stand alone. So that means I have to find one.....or find an entire Hydroboost unit with MC attached.
Thu May 02, 2013 4:20 pm
I'm not sure if this is the right one but I have a hydroboost with the mc attached to it. I do not remember which year it came out of but it is from an Astro van. I needed the push rod and unfortunately damaged the cup that the rod sits in. Yours if you want it.
Thu May 02, 2013 8:41 pm
That's not exactly the same model as yours is designed to mount on an angle.....I'm betting the pushrod may be the same length though. How much do you want for it?
Thu May 02, 2013 8:52 pm
scratch that....if you want it, its yours. Free.
Thu May 02, 2013 9:02 pm
Deal:). Can I get it today? Where are you at?
Fri May 03, 2013 5:42 am
I'm heading to Fountain this morning for an install. I'll be there for a few hours and then head to Aurora afterwords. It might be better to meet up this weekend if you could wait until then.
Fri May 03, 2013 7:26 am
Ok, whatever works for you. If you're coming up I25, you'll be passing right by me in Castle Pines.
Fri May 03, 2013 7:27 am
Ok, I'll grab it and put it in my van. Send me your info and if I have time either way, I'll give you a call to let you know that I can drop it off.
Fri May 03, 2013 7:40 am
Cool..I PM'ed you my #. I can meet you right off I25 at Castle Pines Pkwy if you have time.
Thanks.
Fri May 03, 2013 7:42 am
Fri May 03, 2013 8:38 am
Fri May 03, 2013 8:52 am
Any chance we can meet up tomorrow?
Fri May 03, 2013 9:46 pm
I have brakes! Thanks Rob:)
Sun May 05, 2013 6:06 pm
Sweet!! I'm glad to have helped, Eric.
Sun May 05, 2013 10:46 pm
Which master cylinder are you running on the front there Airbur?
Sun May 05, 2013 10:49 pm
Astro Van MC as well.
Mon May 06, 2013 1:21 am
Mon May 06, 2013 1:22 am
Users browsing this forum: No registered users and 104 guests
33,091,836 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
