www.ColoradoClassicBroncos.com - View topic - 220v adapter
It is currently Mon Nov 25, 2024 6:55 pm
Reply to topic  [ 6 posts ]
 220v adapter
Post 220v adapter
Just confirming what I've tracked down elsewhere since the interweb info isn't 100% consistent. I need to make an extension cord for my welder to run it off my dryer outlet. 4 prong dryer outlet, 3 prong welder. The diagram below is correct, right?
Sat Jun 22, 2013 12:44 am
Post Re: 220v adapter
correct except your white while is also a hot. 3prong 220 doesn't have a neutral.
Sat Jun 22, 2013 5:42 am
what size wire are you using and what distance?
30ft and 10ga. The welders manual calls for 12ga and a max of 50ft, I figure this will give an added margin. Mine may have a white wire, there is a good chance I'll repurpose a 110 cord. I might sharpie the wire black just to stay closer to code.
Sat Jun 22, 2013 7:59 am
You can run regular 110v (black/white/ground) wire as 220v. I've done it a few spots in my house, bathroom heat, irrigation pump, and my compressor. No recolor coding. In 4 wire 220v the "other" hot line would be red.
Sat Jun 22, 2013 8:07 am
Thanks for the help, guys. Got the cord made up today and testing it didn't let any smoke out of the welder.
Sun Jun 23, 2013 6:37 pm
Users browsing this forum: No registered users and 82 guests
33,086,395 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
