www.ColoradoClassicBroncos.com - View topic - Question Ruff stuff steering
It is currently Mon Nov 25, 2024 4:54 pm
Reply to topic  [ 4 posts ]
Post Question Ruff stuff steering
I have a question on the steering before I order. Is it better to reem the knuckles or to drill the knuckles out and install the tie rod tapered insert?
thanks Alex
Sat Nov 02, 2013 10:21 am
Post Re: Question Ruff stuff steering
I'd ream the knuckles. The taper helps prevent the hole from developing slop. The inserts work fine, but the taper is better.
Sat Nov 02, 2013 10:36 am
On the other hand..........
If you ream it you can only go so far which leaves an hour glass effect and not as much contact surface.
I'm drilling mine and using the insert.
Sat Nov 02, 2013 3:55 pm
I have a set if drilled knuckles for ruffstuff heims
Sun Nov 03, 2013 7:09 am
Users browsing this forum: No registered users and 113 guests
33,075,481 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
