www.ColoradoClassicBroncos.com - View topic - Explorer cam
It is currently Mon Nov 25, 2024 2:21 pm
Reply to topic  [ 12 posts ]
 Explorer cam
Post Explorer cam
I'm going to the explorer EFI set up while still using my 72 block for now which means the wrong firing order. Slim chance but I figured I would see if any one had a cam from a late 90's explorer 5.0?
Sun Jan 05, 2014 8:43 pm
Post Re: Explorer cam
Last edited by crawlercreations on Sun Jan 05, 2014 9:06 pm, edited 1 time in total.
Sun Jan 05, 2014 8:49 pm
I need the roller block before if get the roller cam... Duh
Sun Jan 05, 2014 8:58 pm
It will still run fine with the old order
Mon Jan 06, 2014 12:36 am
I bet EFI Guy can reprogram the spark plug & injector firing order to match the cam. He can do it with the Mustang EFI. I'm running the Mustang EFI with my old cam and incorrect injector firing order, and it runs fine.
You might be able to use the Explorer cam, there are aftermarket "dog bone" retainers to fit roller lifters in an old block. I'm not 100% sure how its done, but I think it will work.
Mon Jan 06, 2014 9:17 am
L
Mon Jan 06, 2014 9:36 am
I put a 351 cam in that is the right firing order. Wasn't to expensive.
Mon Jan 06, 2014 9:44 am
Mon Jan 06, 2014 10:36 am
Mon Jan 06, 2014 10:47 am
Im just going to roll with what i have since everyone says it will run fine. Down the road ill do the full swap with a explorer motor plus the 4r70w
Mon Jan 06, 2014 1:14 pm
VENDOR
VENDOR
Mon Jan 06, 2014 6:06 pm
You are the man!
Mon Jan 06, 2014 6:12 pm
Users browsing this forum: No registered users and 35 guests
33,052,392 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
