www.ColoradoClassicBroncos.com - View topic - Good morning at the local yard
It is currently Mon Nov 25, 2024 12:42 pm
Reply to topic  [ 5 posts ]
Post Good morning at the local yard
Managed to pull a hydroboost from a GMC Safari with the master cylinder and a 93 F250 steering box. Heading out this afternoon to pick up a 79 bronco steering box. Some work and a few more parts and I'll have power steering and brakes. Any recommendations on a dual return Saginaw pump? I'm thinking I may break down and just get one from one of the vendors with the pulley and bracket.
Fri Mar 14, 2014 2:10 pm
Post Re: Good morning at the local yard
COS Upull has a 78 Lincoln with a dual return Saginaw and Hydroboost in it. As far as brackets are concerned, the only Windsor I saw with a Saginaw was a van running a serpentine set up.
Fri Mar 14, 2014 3:30 pm
The sag box w/ bracket from the V pulley vans work well. You just need to mod the slot for the bronco bolt pattern. It's not dual return, but I've had good luck with a T in the return line.
Fri Mar 14, 2014 3:31 pm
'78 Lincoln is the standard order for a dual return from the parts store. There is varying success with a T in the line. My T-ed brakes drag for a second or two when I let off while the booster releases pressure. I've grown to like it, but it may annoy others.
Fri Mar 14, 2014 4:22 pm
Looks like I'll head back tomorrow to look for a pump bracket and pulley then. The Lincoln pumps are fairly inexpensive so I'll have to give that a whirl.
Fri Mar 14, 2014 9:52 pm
Users browsing this forum: No registered users and 70 guests
33,043,855 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
