www.ColoradoClassicBroncos.com - View topic - Any 2M / HAM folks out there?
It is currently Mon Nov 25, 2024 8:29 am
Reply to topic  [ 25 posts ]
Post Any 2M / HAM folks out there?
I'm going to pick up a handheld unit. I was very disappointed by the radio setup we used this last hunting season. Looking for someone to talk to (in person and over the air) so I can get some pointers. I'm already studying for the technician license and I'll get that knocked out ASAP.
Mon Oct 20, 2014 11:08 am
Post Re: Any 2M / HAM folks out there?
I can put you in touch with some ham nerds from work if you like. Two technicians, one studying for general.
Mon Oct 20, 2014 11:15 am
I have my tech license, but haven't been active for 6+yrs. For a handheld, Yaseu makes a couple great ones that are compact and water resistant yet still pack a decent punch as far as wattage. You can also use a Yaseu mobile in your vehicle to connect the two and setup your own quasi repeater network - that is handy if you are in canyons etc and can't reach a repeater with your hand held, but you can reach your vehicle and it can reach the repeaters.
-Ben
'74 Bronco / Garage art - in stages of rising again
..figured out how to change my dork picture!
Mon Oct 20, 2014 12:20 pm
There used to be a fairly active Boulder HAM club that would be a great source of info.
-Ben
Mon Oct 20, 2014 12:22 pm
I also know a few folks from the 4x4 club I used to run with in Denver. In fact, I think one of them is an instructor. Let me know if you want contact info.
Tue Oct 21, 2014 2:36 am
Thanks for the replies & recommendations, I'd appreciate contact info.
Tue Oct 21, 2014 7:24 am
N0KHC here, have been for 25 years or so. Tech Plus.
I will be willing to help or recommend. I was very active when I still had my Dad but backed off after he passed away. He was very active and I pursued it to stay in touch with him.
2 Meters is great but the thing you run into is there are few others around that have the rigs, so I always have had a few laying around for that reason. Let me know if you have any questions or if I can help. I prefer ICOM but have some Radio Shack 440 hand held as well. I don't think Radio Shack carries anymore but they work well.
I have a 65 watt amplifier I have used mobile before, and of course a great antenna mounted instead of the rubber duck is really a great way to get your signal strength up.
For every 3db of gain it doubles your signal. So when looking at antenna etc just think about that when you are trying to get set up. 5 watt handhelds are great but need to have good batteries and antenna to keep that signal up. The battery packs are lacking and if you can get a good lead for the handheld to feed from you 12v DC source you will be better off.
Owned my 1972 since 1985
Canon City, Co
Tue Oct 21, 2014 8:39 am
Thanks, I'm reading as much as possible and have read the antenna & cable are just as important as the radio. Plan is to get a couple of hand held units to start and then a vehicle mounted.
I'll get a 12v power source for the hand held radios, thanks for the tip.
Tue Oct 21, 2014 11:54 am
Had my Tech for almost 7 years now. I got started on Yaesu radios because of certain features and style, and have stuck with them.
Currently I own three:
FT-8800R was my first unit. It was purchased for its dual band and cross-band repeater capabilities.
VX-6R was my second unit. Portable, dual-band, feature rich and best of all, waterproof
FTM-350R, because I got into APRS (triple-band, are you sensing a theme here?)
There are many options out there depending on what you need to do. I needed a better solution than CB or FRS for wheeling. That morphed into needing a portable for snowmobiling with my friends. The snowmobiling led to APRS for tracking group members instead of just voice communications. The FT-8800 is nice for working a remote area, I can park the truck on a high spot and use it as a make-shift repeater for the hand talkies.
I've even mated a single board computer to a radio modem kit running tracking software.
I probably dork-out in the most on the APRS stuff, but the improved range and quality of the voice communications alone is a reason to switch.
Build Thread:
Tue Oct 21, 2014 12:07 pm
Tue Oct 21, 2014 1:54 pm
Build Thread:
Tue Oct 21, 2014 4:54 pm
KB0KPN here. Booger is N0GPW. I have a 2m mounted in my bronco but never turn it on as no one ever uses it.
Thu Oct 23, 2014 4:31 pm
Maybe we'll start a trend.
Thu Oct 23, 2014 8:19 pm
I've thought about it for years. Haven't made the leap as I didn't have anyone I actually wanted to talk to. If we wind up with a bunch of HAM operators I'd probably jump on board.
Thu Oct 23, 2014 11:25 pm
Looks like we are up to 5 tech license holders just in this thread, I bet there are a few more in the background. As soon as I get up and running I'll do a bit of research on local groups and freqs, we can either join into an established setup or setup our own if there is enough interest.
Fri Oct 24, 2014 9:42 am
There are plenty of established groups out there. Here is a list of local clubs.
You will run into many people that are into HAM for different reasons. Many older guys I've met like the social aspects, others like the technical merits, others still are in it for practical reasons like Search & Rescue or like us, just need a better form of comms for club related activities. I tend to fall into the last two groups. I got started out of a need for something better than CB, but soon realized the greater potential of HAM in general. (I say greater, because it is difficult to fully realize what can be done, given HAM radio's constantly evolving nature)
Here is list of state repeaters:
Colorado is a great place for HAM guys. We have lots of high peaks to place repeaters on that allow signals to propagate for 100s of miles. It makes 2m and 70cm very effective in this area. There is even a state-wide repeater network that is radio-linked and doesn't rely on any outside infrastructure. You can key-up in Denver and talk to someone in Durango, Grand Junction, and Walden all at the same time!
Getting your ticket is fairly simple, especially if you have a basic understanding of electrical and radio principals. I'm willing to help anyone out that needs it and my tech license manual is available to borrow.
Build Thread:
Fri Oct 24, 2014 11:18 am
I'm interested in this as well. Have always thought about the benefits but like others didn't know anyone else to make it worth while.
Fri Oct 24, 2014 11:34 am
I've thought seriously about it in part because of the repeater network. I like the idea of being able to call for help with more than a CB if I get in trouble while out in the boonies alone.
Fri Oct 24, 2014 12:32 pm
I use to be on the radio a long long time ago for my job.
Used HF, UHF voice. HF, UHF satellite. HF, VLF, ELF receive and lot's of other goodies, it was a fun job.
Certified 21wpm on morse code, I've heard the code has went away as a requirement for ham radio now? Is that true?
J.E.
Fri Oct 24, 2014 4:29 pm
Yes, no code for tech license, haven't checked higher levels.
Fri Oct 24, 2014 6:14 pm
Sat Oct 25, 2014 8:49 pm
KD0EHD
I've been a tech for several years. I have a Yaesu VX-7R handheld and a 2M/7M Jpole antenna in my attic.
I participate in an Emergency Radio Club 2 times a month to keep my meager skills up.
I took my radio with me a month ago when I was out camping by Taylor park, but I forgot my repeater catalog and couldn't find a repeater. So just having a radio doesn't help much. there are SOOOO many frequencies and options that you've got to have a catalog to find anything. At least I do.
Wed Oct 29, 2014 11:02 pm
Good idea o having a book around, or at least notes - I have most of the repeaters programed in and labeled; if I lost the memory I might be a bit lost too...
-Ben
Thu Oct 30, 2014 10:24 am
I'm looking forward to learning how to program my radio, but I'll definitely carry a little book of local freqs for repeaters.
Thu Oct 30, 2014 7:05 pm
Maybe if you all log on (or whatever you call it) together at the same you could sing Happy Birthday? Happy Birthday Kirk.
Fri Oct 31, 2014 3:50 pm
Users browsing this forum: No registered users and 57 guests
33,032,880 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
