www.ColoradoClassicBroncos.com - View topic - advice/opinions on a new 110v welder or run power to shop
It is currently Mon Nov 25, 2024 6:43 am
Reply to topic  [ 6 posts ]
Post advice/opinions on a new 110v welder or run power to shop
I recently moved to Franktown and have a "barn" that I will eventually need to run power to and have more recently acquired some welding work to be done, it is lighter steel art type stuff. I have a 220v unit already but no power at shop and it would be a bit to run an extension cord that far from the house.
I am currently in the middle of a major house remodel and hadn't planned on getting power to the shop til well into the 2015 year, however this job offer has changed that.
welder I have is a weldpack 180 Lincoln
my options are:
try and get power there officially either sub from the house or another run from the pole(my 1st choice no idea of cost)
make a 70 foot extension cord to run from house and use my 220v welder
buy a 220v capable generator to run my current welder
buy a 110v wire feed and run a big extension cord to the shop or use mu 110 genny if it could handle it
any thoughts or opinions I think I have about a month before the work needs to begin full specs coming on Monday.
no idea what the budget is for this I just would rather not spend money twice, or on something that wouldn't be used again.
lemme know what you alls think
Sat Dec 20, 2014 12:27 pm
Post Re: advice/opinions on a new 110v welder or run power to sho
I have an extension cord thats about 60-70' I use in my garage. I've also ran my welder off a 5kw generator with zero issues on both.
Sat Dec 20, 2014 3:32 pm
Sat Dec 20, 2014 4:41 pm
I just made my 60 ft 220 cord. Cost me $280 with everything from Home Depot. Probably could do it cheaper if you shopped around.
Sat Dec 20, 2014 5:00 pm
A long extension cord now can also be turned into two short ones later. Id get a quote to run the sub panel, and if it's not affordable I'd make the extension cord.
Sat Dec 20, 2014 6:26 pm
Definitely go with the 220V extension.
It's cheaper than a 110V welder.
Build Thread:
Sun Dec 21, 2014 1:07 am
Users browsing this forum: No registered users and 86 guests
33,030,853 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
