www.ColoradoClassicBroncos.com - View topic - Serp front dress
It is currently Mon Nov 25, 2024 6:54 am
Reply to topic  [ 16 posts ]
 Serp front dress
Post Serp front dress
Yes, I have a bad case of Bronco creep. I've got the grill off and the radiator out to move the steering box forwardso it seems like the perfect time to install a serp setup to prep for Explorer EFI. Is any particular year better than another? I'm planning to run Gary's modified harness with coil packs, so probably a 99-ish EFI setup.
Mon Dec 29, 2014 1:43 pm
Post Re: Serp front dress
I think the front dress were all very similar in the 5.0. There are 2 different fan clutch (plastic and steel) that will both work- just make sure if you get a plastic one, there aren't any large cracks in it. You may check with Garry on whether the crank position sensor needs to come from the same year as the EFI harness.
Also- if I remember correctly- you're planning on 37" tires? If so- you'll probably want to strongly consider the Saginaw PS pump conversion. If you'd like to see mine- you're welcome to swing by (I'm still not driving it as I haven't gotten my heater working).
Mon Dec 29, 2014 3:39 pm
Thanks! I haven't decided about spending the money for the Saginaw bracket and pulley vs. buying a WH or PSC pump. I may want to run a Sanden compressor for onboard air down the road, which the saginaw wouldn't let me do.
Mon Dec 29, 2014 4:22 pm
If were you I'd wait till you do the 351 swap, you're not gaining a lot doing it on an engine you plan to pull. Especially considering what you have works
Wed Dec 31, 2014 12:55 am
The explorer serp set-up will bolt onto a 351 so it's not like he'd be out the money.
Wed Dec 31, 2014 7:27 am
I've debated that one too. The bronco fund is way tapped, and my short block is in good shape, so I'm going to convert it to serp and efi. That way the 351 can get rebuilt and maybe stroked when I do move forward with it.
Wed Dec 31, 2014 7:35 am
VENDOR
VENDOR
I haven't noticed any changes in the serp setups aside from plastic vs metal fans. Cranks sensors should all be the same, the cam sensors did change, but you would need to change it again for a 351 anyway.
99+ might be a little better for a 351, the smaller injectors flow more due to the higher pressure. But, you would need an adjustable pressure regulator which adds to the total cost a bit.
Wed Dec 31, 2014 9:04 am
I'm willing to invest the small extra amount to not have to re-do things down the road. I'll go for a 99+ setup. Does the factory pressure regulator work for a 302? Thanks, that helps!
Wed Dec 31, 2014 10:07 am
I've got a '99 fuel rail and injectors (beige/tan) if you need them. I'd let them go for what I paid for them (that is if you don't buy this beast).
Wed Dec 31, 2014 10:50 am
VENDOR
VENDOR
98 and earlier work too, but if you build it hot enough you can run out of injector. But, it's a Bronco, not a dragster so it should be fine. I haven't heard of any one leaning out on a 351w with 19's yet, but they have all been mild builds. If you stroke it you'll want bigger injectors. If you needed to step up to bigger injectors down the road I wouldn't charge you anything to re-tune it as long as you use Ford injectors with known data and not some Ebay garbage.
The 99+ equal pretty close to 24's (23 and some change) so it get's you a little more headroom. But, if you build a pissed off stroker they may not be enough either.
The 99+ rails don't have a fuel pressure regulator, the device on the rails is just a dampener. The regulator is mounted in the tank above the pump and bleeds off the excess pressure right back in to the tank returning it before it leaves the tank instead of returning it at the fuel rail. You would just need an adjustable fuel pressure mounted on the frame rail. You would then run a return from the fuel pressure regulator back to the tank. The catch is you need to make sure the pump, regulator, and anything else in the system can handle 65 PSI.
Or get real crafty and mount the entire 99+ pump / regulator assembly in to your tank.
Wed Dec 31, 2014 10:57 am
Hmmm, I like the idea of mounting the pump/regulator assembly in the tank, but after looking at the sending unit assembly it could be a massive PITA. I've been thinking about some tank mods for axle clearance and fuel return anyway, but need to find out how likely I am to have problems if I attempt to weld a well-used tank. Have heard many horror stories. What pressure does the '99+ system get regulated to? Not planning to build an angry stroker if I do it at all, more likely a mild 393 or 408. I figure that a stroker kit may cost about what a rebuilt kit plus the charges to clean everything up.
Wed Dec 31, 2014 1:19 pm
VENDOR
VENDOR
Thu Jan 01, 2015 10:24 am
All the way to the fuel rail? That'd be a bummer, i don't think my fuel lines are rated for that.
Thu Jan 01, 2015 11:25 am
VENDOR
VENDOR
I'd run steel hard line most of the way, and use the donor Explorer fuel line with fittings at the rail. Keep the rubber EFI line to minimum, only use it between the hard line on the frame and the fuel tank.
Thu Jan 01, 2015 11:50 am
I had thought the tube I made mine from was annealed aluminum. Turns out it's steel and I'm forgetful. Problem solved. Whats the best way to set up the lines for the factory couplers? I've got a bunch of very pretty AN fittings spare, so a clean way to adapt to those would make me happy.
Thu Jan 01, 2015 12:20 pm
VENDOR
VENDOR
I'm sure you can flare the hard line for AN. I've seen AN adapters for the Ford rails as well.
I'm a cheap SOB, I bubble flare the hard line to act as a hose barb for attaching rubber line with clamps. I cut the EFI fittings out of junkyard nylon lines. They have nice barbs for attaching rubber line to. But, I still like to keep the use of rubber line to only a couple of inches.
Fri Jan 02, 2015 11:43 am
Users browsing this forum: No registered users and 71 guests
33,031,312 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
