It is currently Mon Nov 25, 2024 6:39 am
[ 13 posts ] |
Rough estimate
Anyone care to venture a guess/estimate on replacing both floorboards, both kick panels, and both front door posts? No painting. Only cutting out old sheet metal and replacing with repop stuff.
Sat Jan 03, 2015 4:46 pm |
Re: Rough estimate
Are you outsourcing the work?
Sat Jan 03, 2015 5:41 pm |
Re: Rough estimate
Yes. This would be an estimate for a shop to do the work. Basically looking to see what opinions are regarding what you would expect to pay.
Sat Jan 03, 2015 5:45 pm |
Re: Rough estimate
$4500
Sat Jan 03, 2015 6:30 pm |
Re: Rough estimate
Monday, I'll check to see if our estimating system has info for our trucks. I'd guess a shop might throw the estimating system out the window, due to probability of finding unexpected problems, and charge actual hours worked. We charge $69/hr. So Chris's figure works out to 65 hrs. Probably not too far off of what the estimating software would calculate.
Sat Jan 03, 2015 9:39 pm |
Re: Rough estimate
Re: Rough estimate
Sat Jan 03, 2015 9:51 pm |
Re: Rough estimate
65 hours sounds about right, maybe a little high.
Sat Jan 03, 2015 9:57 pm |
Re: Rough estimate
Sat Jan 03, 2015 11:15 pm |
Re: Rough estimate
I've heard that about you.
Sat Jan 03, 2015 11:32 pm |
horseplay
Re: Rough estimate
The guy's in the springs told me about $3500 including parts to do posts & front floor panels.
Sun Jan 04, 2015 12:11 pm |
Re: Rough estimate
Thanks for the input guys. Think I have what I need.
Sun Jan 04, 2015 2:18 pm |
Re: Rough estimate
Sun Jan 04, 2015 2:30 pm |
[ 13 posts ] |
Users browsing this forum: No registered users and 82 guests |
