www.ColoradoClassicBroncos.com - View topic - Knuckle confirmation
It is currently Mon Nov 25, 2024 1:24 am
Reply to topic  [ 12 posts ]
Post Knuckle confirmation
Guys, the knuckles on the '76-'77 Bronco axles are the same ones that are on the '78-'79 Bronco and '72-'79 F150, right? That's my recollection, and my google-fu appears to be malfunctioning.
Wed Aug 26, 2015 7:29 pm
Post Re: Knuckle confirmation
I don't think so. If I remember correctly where the tie rod mounts is in a slightly different position or thickness. That's what causes them to rub on 15" rims. Someone can correct me if I'm wrong though.
Wed Aug 26, 2015 8:40 pm
Phyler is correct. The 76 and 77 knuckles where the tre mounts are slightly bent toward the tire where as the 78-79 are straight and slightly lower and just a bit beefier.
Wed Aug 26, 2015 10:23 pm
Cool, thanks. Anyone able to provide the measurement between the center of the knuckle hole where the tire rod connects on the '76-'77 knuckles?
Wed Aug 26, 2015 10:27 pm
Thu Aug 27, 2015 12:51 am
Thu Aug 27, 2015 9:12 am
If I remember correctly the 78-79 knuckles also have more clearance around the axle.
Thu Aug 27, 2015 4:40 pm
Thu Aug 27, 2015 6:35 pm
Thu Aug 27, 2015 6:38 pm
I'm not going to get over to the 76 until after the weekend.
Thu Aug 27, 2015 6:53 pm
Whenever, it's not urgent. Thanks for being willing.
Thu Aug 27, 2015 7:24 pm
Thu Aug 27, 2015 8:37 pm
Users browsing this forum: Google [Bot] and 57 guests
33,021,088 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
