It is currently Mon Nov 25, 2024 1:56 am
[ 8 posts ] |
Anyone close to DIA?
I'm in the parking lot and the super duty seems to have lost the ability to cold start in 40* temps. Could use some jumper cable action while I cycle the glow plugs.
Fri Oct 30, 2015 11:57 am |
phyler
Re: Anyone close to DIA?
I could be out there around 2:30 if you are still stuck. On a call until 2pm. I'm about 30 minutes away. I'll call you when I'm done with my call.
Fri Oct 30, 2015 1:22 pm |
Thanks again Adam. You're a life saver. I owe you big.
Fri Oct 30, 2015 3:44 pm |
phyler
Hope you made it home safe. Glad I could help.
Fri Oct 30, 2015 8:58 pm |
Damn Xach you shoulda called me. Im Live about 15-20 minutes away. I could have swung by there on my way home from work as I was heading home at that time.
Sat Oct 31, 2015 7:28 am |
Mon Nov 02, 2015 4:36 am |
Mon Nov 02, 2015 6:55 am |
It's a combination of issues. Mostly revolving around the injectors I suspect. With 225k on the odo, the first part of its life spent in Texas, and three transmissions, I think it just had a little bit of a hard life in the beginning.
I'll be pulling the injectors this week to put new o-rings on them and see if that makes a difference. If not, I'll be ordering up some Stage 1s from Ryan Casserly at Full Force Diesel, a Terminator T500 HPOP and new tunes from DP or PHP. Combined with the need for new tires AND a regear, and it's not going to be a good season for the Bronco fund.
Mon Nov 02, 2015 7:17 am |
[ 8 posts ] |
Users browsing this forum: No registered users and 71 guests |
