www.ColoradoClassicBroncos.com - View topic - Fuel tank J bolt source? Brick and mortar
It is currently Sun Nov 24, 2024 11:42 pm
Reply to topic  [ 12 posts ]
Post Fuel tank J bolt source? Brick and mortar
I've just about had it with the ridiculous shipping costs associated with many of the Bronco parts houses. Last night I started to place an order for two new J bolts to reinstall my auxiliary tank. When the cost of shipping nearly exceeded the cost of the actual hardware, I said enough is enough.
I'm looking for a brick and mortar source for J bolt replacements. Has anyone had any luck with doing a local purchase on these?
Home Depot, not surprisingly, had nothing that was a direct fit option. Several options I could modify to work, but the risks of damage to the hardware were not worth it to me.
Thu Jan 07, 2016 1:20 pm
Post Re: Fuel tank J bolt source? Brick and mortar
I feel your pain on shipping. I said enough is enough when the local bronco parts supplier charged me shipping on a fuel tank that I went and picked up from them.
You may try O'Reillys or Advanced before going to extremes.
Thu Jan 07, 2016 1:36 pm
You've tried grainger or fastenal?
Thu Jan 07, 2016 3:15 pm
I ended up making my own using a torch to get the bend right.
Thu Jan 07, 2016 3:19 pm
I also made my own J-Bolt vs. the cost of buying one.
Thu Jan 07, 2016 3:56 pm
I probably have a couple laying around if you're interested in used...
Fri Jan 08, 2016 8:39 am
Sorry I know you asked for brick and mortar but what about McMaster.com?
http://www.mcmaster.com/#j-bolts/=10lpais
Sat Jan 09, 2016 1:09 am
Sat Jan 09, 2016 2:32 am
Sat Jan 09, 2016 2:34 am
Sat Jan 09, 2016 11:00 am
I don't know what size they are but here is the selection from fastenal.
https://www.fastenal.com/products/j-bol ... categoryl1:
Sat Jan 09, 2016 11:02 am
Users browsing this forum: No registered users and 40 guests
33,018,693 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
