It is currently Sun Nov 24, 2024 7:35 pm
[ 12 posts ] |
Trailer Q and A
Figured since there are quite a few trailers in the group, a thread about them might be good.
And to kick it off...
Tires. My trailer, a 20' dovetail, has had three flat tires now. Oddly enough they've all been on I 70 in Junction City, KS.
Currently I am running the same size that was in when I bought it; 205/75/15, Load C.
If'n some of you fellas wouldn't mind, could ya tell me your general trailer specs and tire sizes you're running?
Wed Dec 07, 2016 6:59 pm |
Re: Trailer Q and A
7000 lb 16 ft dovetail, 1 ea 225/75/15 load C, 1 ea 225/75/15 load D, 2 ea 225/75/15 load E, and 1 ea 205/75/15 load C (spare).
Wed Dec 07, 2016 8:06 pm |
Re: Trailer Q and A
My trailer:
7000 lb, 20' tilt deck, 2300 lbs dry weight. Trailer came with 205/75 15 bias plys. Tires were junk, I burned them up after a few years. Upgraded to 235/75R15 Radials Load D. Tows better and less heat generated from the tires when traveling fully loaded at 75mph.
Wed Dec 07, 2016 8:59 pm |
Re: Trailer Q and A
Thu Dec 08, 2016 7:59 pm |
ManTruck
Re: Trailer Q and A
_________________ Owned my 1972 since 1985
Canon City, Co
Mon Dec 12, 2016 10:08 am |
Re: Trailer Q and A
Mon Dec 12, 2016 4:29 pm |
Re: Trailer Q and A
I went back and looked. Tires are actually 235s
Here is the old 205s
And newer 235s
Wed Dec 14, 2016 9:11 pm |
Re: Trailer Q and A
Wed Dec 14, 2016 9:15 pm |
Re: Trailer Q and A
Bulldog connector I really like the trailer. I bought it with the DOT package, so I got the better connector, dual axle brakes, extra lighting, etc.
Thu Dec 15, 2016 11:20 am |
Re: Trailer Q and A
Fri Dec 16, 2016 11:50 pm |
Re: Trailer Q and A
Mon Dec 19, 2016 11:07 am |
Re: Trailer Q and A
The upgrades were definitely worth the extra $200-300 I paid for the trailer. This summer, now that it is 10 years old, I dumped another $800 into the trailer to re-deck, re-wire, upgrade to LEDS, re-paint, and re-brake it. Combined with the original purchased price, I'm still under what a new one costs. Trailers are expensive. If I had known then what I know now, I would have bought two and sold one.
Tue Dec 20, 2016 11:16 am |
[ 12 posts ] |
Users browsing this forum: No registered users and 73 guests |
