www.ColoradoClassicBroncos.com - View topic - Death wobble
It is currently Sun Nov 24, 2024 7:42 pm
Reply to topic  [ 12 posts ]
 Death wobble
Post Death wobble
It just started today. Was going slower speeds like 10 20 mph when the whole Bronco started to shake really bad to the point of almost having to come to a full stop be for it would quit. Would king pins cause this problem or should I be looking elsewhere?
Sat Feb 18, 2017 1:58 pm
Post Re: Death wobble
Or ball joints (if d44) or trackbar bushings.
Sat Feb 18, 2017 1:59 pm
Which truck Matt big blue or the half cab two different set UPS
Sat Feb 18, 2017 4:41 pm
Profile WWW
Sat Feb 18, 2017 8:32 pm
I would check the trackbar first.
Build Thread:
Sat Feb 18, 2017 10:23 pm
I'd start be replacing all the front end bushings including the c bushings. An afternoon of work and not too expensive!
Sat Feb 18, 2017 10:45 pm
x3 or whatever on the track bar bushings. If that doesn't do it, I'd go through the rest of the bushings in the front end.
Sun Feb 19, 2017 12:15 am
Images: 11
X4, this solved the problem on mine.
Sun Feb 19, 2017 7:43 am
Hey Matt because your swapping in the D44 I wouldn't get to busy unless it's just the track rod bushings.
Sun Feb 19, 2017 10:47 am
Profile WWW
Sun Feb 19, 2017 1:27 pm
Have someone steer the wheel back and forth from say 10 o'clock to 2 while you start looking for play from track-bar all the way to the steering box.
Mon Feb 20, 2017 9:23 pm
Thanks again for the input it sure helps out.
My findings:
I had someone move the steering wheel and found that both of my tie rod ends were way loose once I tightened them up the cotter pins didn't even touch the castle nut so I added some washers and now it's good to go. I also had boots ripped so those got replaced. Greased and once again it's a happy truck.
Tue Feb 21, 2017 6:20 pm
Users browsing this forum: No registered users and 84 guests
33,012,491 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
