www.ColoradoClassicBroncos.com - View topic - EFI throttle cable
It is currently Sun Nov 24, 2024 10:31 am
Reply to topic  [ 16 posts ]
 EFI throttle cable
Post EFI throttle cable
What is everyone running for a EFI throttle cable? I'm eyeballing the BC Broncos setup, but figured I'd double check to see if it was the best bang for the buck before I ordered.
Sun Mar 26, 2017 12:04 am
Post Re: EFI throttle cable
I'm running BC
Sun Mar 26, 2017 12:07 am
Be x 2
Sun Mar 26, 2017 4:25 am
BC with the viper mod
Sun Mar 26, 2017 7:15 am
Viper mod?what is that and is there any pic and reason for it?
Sun Mar 26, 2017 7:32 am
Has nothing to do with a Dodge Viper but rather a mod dreamed up by Viperwolf1
It involves mounting a small pulley on the throttle blade which creates a graduated throttle response for the first 20% of pedal. I can't find the pics at the moment but I bet Phil can post them up and explain better.
Great for wheelin'.
Sun Mar 26, 2017 7:44 am
Thanks guys, I'll order up the cable.
Sun Mar 26, 2017 8:13 am
Sun Mar 26, 2017 10:41 am
I went with WH. Same cable as BC's I just wont do business with BC's again.
Mon Mar 27, 2017 11:53 am
Mon Mar 27, 2017 12:21 pm
Went with the lokar one,all the others you had to cut to fit and if you messed up then you had to order a new one.the lokar one slid through the fitting so I could make it longer or shorter any time
Mon Mar 27, 2017 1:04 pm
I'm a cheap a$$ and used a stock cable from a cougar on mine and my brother in laws. They required modifying the stock gas pedal but they both work and feel like stock. Best of all they were less than $5 each.
Mon Mar 27, 2017 5:11 pm
I'm with @valentino The Lokar cable is superior in a few ways.
Mon Apr 03, 2017 1:47 pm
Have a link handy for the Lokar cable? I have the BC also. I think it could be better......
Mon Apr 03, 2017 5:01 pm
I think these are the parts I used:
https://www.summitracing.com/parts/lok-tcb-40efi
https://www.summitracing.com/parts/lok- ... /overview/
Mon Apr 03, 2017 7:46 pm
thumbs up thx
Tue Apr 04, 2017 9:18 pm
Users browsing this forum: No registered users and 57 guests
32,997,251 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
