Register •
FAQ
• Login
It is currently Sun Nov 24, 2024 5:25 pm
[ 4 posts ] |
BOBS 2 68S
Fuel pressure regulator
I am changing back to the Edelbrock carb. This time with a fuel pressure regulator. Found that Edelbrock carbs do not like high fuel pressure. Those that are running regulators where did you mount it. I have the Holley adjustable with gage port. I am using a drop base air cleaner so mounting off the carb base will not realy work. I thought about mounting to a inner fender or fire wall but a bit worried about the longer fuel lines.
Thu Jun 22, 2017 5:19 am |
Re: Fuel pressure regulator
I ran one for years mounted on the front of the intake manifold, near the t-stat housing. Mine was a Mallory with a return line to the tanks.
Thu Jun 22, 2017 6:46 am |
as close to the carb as possible.
And yes edelbrocks don't like over 5-5.5psi
Thu Jun 22, 2017 7:25 am |
3 psi is a good wheeling pressure just a bit to low for the road. Mount it as close as you can to carb to minimize vapor lock.
Thu Jun 22, 2017 9:23 am |
[ 4 posts ] |
Users browsing this forum: No registered users and 73 guests |
