www.ColoradoClassicBroncos.com - View topic - 3rd Brake Light with White Reverse/Backup light
It is currently Fri Nov 22, 2024 12:44 am
Reply to topic  [ 8 posts ]
Images: 14
Post 3rd Brake Light with White Reverse/Backup light
I copied a picture of one of Phils diagrams on classic Broncos.com I hope he doesn’t mind.
Mine is a 68 but I think the coloring on the wires is basically the same.
Can someone tell me what color(s) to run to the (3rd) red brake light and which color(s) to run to the (3rd) back up light?
Passenger
Green
Brown
Blk/Red
Drivers
Yellow
Brown
Blk/Red
License plate bulb
Brown
The third brake light basically has one wire for the RED light with one ground wire
And basically the same for the reverse light, one wire with a ground as well
It’s listed as cargo lamp but I want to hook it up as my reverse light!
Mon Mar 02, 2020 1:57 pm
Post Re: 3rd Brake Light with White Reverse/Backup light
Brown is marker/taillights. Just hooked mine up yesterday. Yellow is stop.
I used the wiring diagram at seabiscuit68.tripod.com.
Adam
Mon Mar 02, 2020 5:47 pm
Images: 14
So if I want the Tail light to act like a marker light and a brake light then I need to wire both the Brown and Yellow wires to it?
And I’m assuming the black and red is the back up light wire?
Mon Mar 02, 2020 7:01 pm
Mon Mar 02, 2020 7:04 pm
I wired up a similar light mounted on the top back part of my roll bar. I ended up running a separate brake light from the switch back to the 3rd brake light because it kept blinking with the turn signal from one side or the other. Backup was as easy as pulling from the wires in the tail-light, and running hot wires from each brake light wasn’t going to work. FYI.
Mon Mar 02, 2020 10:01 pm
Images: 14
Thank you Gentleman!
Tue Mar 03, 2020 7:58 am
Black-red is reverse light.
If you don't want the 3rd brake light to flash with turn signals you need to run a new wire directly from the brake light switch (before it gets to the turn signal switch).
Tue Mar 03, 2020 9:40 am
Images: 14
Tue Mar 03, 2020 12:50 pm
Users browsing this forum: No registered users and 10 guests
32,935,860 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
