www.ColoradoClassicBroncos.com - View topic - Rox Crusher's frame off refresh and 5.0 EFI swap
It is currently Sun Nov 24, 2024 9:32 pm
Reply to topic  [ 283 posts ]  Go to page 1, 2, 3, 4, 5 ... 10  Next
Post Rox Crusher's frame off refresh and 5.0 EFI swap
Bought a 5.0 EFI Explorer engine this week-end so no turning back now.
Not sure how soon I will be putting it in though.
Gotta get harness and other related "stuff".
Sun Feb 27, 2011 10:03 pm
Post Re: Taking the EFI plunge
Might make a couple of good tech days as part of the project. Swapping an engine, EFI wiring, etc. You know, the stuff that Viper does during catnaps.
Sun Feb 27, 2011 10:29 pm
I agree a tech class would be a great way to help get new motor installed. With the number of EFI's in the club, you should be able to do it right the first time. Going to be fun to see it come together and the costs and parts involved.
Mon Feb 28, 2011 12:54 am
You gonna do the 2 pump system ??, or get the intank pump/tank set up?? It's cheaper to do the LP-HP setup, so you have more lettuce for the harness.
Mon Feb 28, 2011 4:23 am
Mon Feb 28, 2011 8:07 am
Have you seen BC's accumulator setup? I'm thinking that when I go EFI (in 1000 years) I'll likely go this way. http://www.bcbroncos.com/fuelefi.html about halfway down.
Mon Feb 28, 2011 9:46 am
I would look at adding an in-tank pump to the BCB tank. Might need to weld in some baffles for the pump. The external accumulators and pumps can be finicky at high altitude/temp. Plumbing and wiring would be a lot cleaner with an in-tank pump too.
Mon Feb 28, 2011 11:19 am
I have heard in-tank fuel pumps last a lot longer because they are cooled by the fuel vs. external fuel pumps.
Mon Feb 28, 2011 11:31 am
i have a slightly used accumlator from bcb and a carter external low flow pump, both were installed, engine fired up and then replaced with an in tank system. I also have a efi harness from a 89 mustang. If anyone here wants them call me or pm me.
next breakfast at golden corral i can let anyone that wants take a look at my efi setup.
73', 302 w/EFI, C4, locked frt-rr, 5:13, 6"WH springs, 3" body, 35"MTR, 6pt cage.
Tue Mar 01, 2011 11:56 am
Got it home last night.
Guy decided to throw in the wiring harness but pretty sure I won't be using it.
Sounds like I need to go with the in tank pump set up.
Wed Mar 02, 2011 5:34 am
Rox, I have a spare in tank pump NIB if you want it. Trade you for your expertise on hydroboost.
Wed Mar 02, 2011 9:12 am
Seeing Zilla's low mileage (read super clean) 5.0 engine during the gear install tech session motivated me to get started on getting mine ready for installation this fall.
Viper graciously came over on Sunday and gave me some great advice on what I can and can't use (thanks again Phil).
Tonight I cracked that egg open and to my untrained eye everything looks really good.
Mon Jun 27, 2011 9:58 pm
Commemorating the 4 month anniversary of your buying the motor? laughing2
Looks like fun! Been thinking of pulling the trigger myself but too many irons in the fire as it is. Maybe this winter...
Mon Jun 27, 2011 11:37 pm
I'll be watching, I've got a 96 Explorer motor waiting. Since money is tight, and my carb'd motor is good, it will be waiting for a while. I'd see what I could do about coming to Denver to attend an efi swap. I think I've done enough reading to know most of what to expect, but I'd love to see it done.
Chad
Tue Jun 28, 2011 12:12 pm
That does look pretty clean inside Jeff. I wouldn't tear it down any more than that. Just run it as is. That has the re-usable pan gasket too.
Tue Jun 28, 2011 1:10 pm
i'd wait til winter to do it , i think mine took about 2 months to get it all bought and ready to install
Tue Jun 28, 2011 6:29 pm
Tue Jun 28, 2011 9:19 pm
Images: 1
Tue Jun 28, 2011 10:19 pm
Post Re: DANG IT SPENCER ! ! ! ! ! ! !
DANG IT SPENCER, I TOLD YOU TO STAY OUT OF MY TOOLS ! ! ! ! ! ! ! !
and so the swap has officially started
icon biggin
Sun Oct 16, 2011 7:38 pm
Which tank and fuel pumps did you go with?
Sun Oct 16, 2011 8:09 pm
Thats and awesome pic. Glad to see you making progress.
Sun Oct 16, 2011 8:20 pm
Sun Oct 16, 2011 8:28 pm
Cool deal....going to paint the engine bay or is it in good condition?
Sun Oct 16, 2011 8:40 pm
Mon Oct 17, 2011 1:14 am
Sounds like a great plan! Are you going to rebuild the tranny/transfer case while you have it all open? Or was that done recently? What color are you going to paint the bay? I found a source for the original Ford OEM colors and am planning to do that do mine.
Mon Oct 17, 2011 6:24 am
Mon Oct 17, 2011 6:42 am
Mon Oct 17, 2011 9:09 am
Mon Oct 17, 2011 12:43 pm
Post Re: Explorer 5.0 EFI SWAP
makin progress on the motor
Sat Nov 05, 2011 4:34 pm
Beautiful!!!
Sat Nov 05, 2011 5:35 pm
33,015,291 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
