www.ColoradoClassicBroncos.com - View topic - Starting to think about a 302 to 347...naw....427:) rebuild.
It is currently Sun Nov 24, 2024 3:34 pm
Reply to topic  [ 53 posts ]  Go to page 1, 2  Next
Post Starting to think about a 302 to 347...naw....427:) rebuild.
Here's the basic question....can I take the '70 block I have, get a machine shop to clean it up and bore it to fit one of the popular 347 stroker kits, then add a top-end kit and finish it off with a later model 5.0L EFI setup?
Mon Jul 25, 2011 7:16 pm
Post Re: Starting to think about a 302 to 347 Rebuild
I don't see why not. If you are looking for someone that can build it for you, send me a pm and I can get you his information. He is somewhat of an expert at helping people build an engine for their specific requirements. We were actually talking about this the other day. He has been thinking about some engine seminars to help people determine what they need to make the perfect engine combo.
Mon Jul 25, 2011 7:44 pm
Eric, as long as you are going to drop the coin on stroker kit, why not throw in the extra couple hundred for a roller block? Still get to drive your Bronco while it is getting built.
Mon Jul 25, 2011 8:47 pm
I would avoid a 347. Limit the 302 to 331ci. When you get into the 347 range you start pushin small pistons and the wrist pins is in the oil control rings. Unless they have changed it up in the last few years.
Mon Jul 25, 2011 8:51 pm
Get a 351W and Go to a 408 stroker kit....oooooohhh yeaahhhh!!
Mon Jul 25, 2011 9:36 pm
Mon Jul 25, 2011 10:14 pm
Quick internet search says "yup, sure can".
Mon Jul 25, 2011 10:36 pm
Yep..... http://www.jegs.com/i/JEGS-Performance- ... 0/10002/-1
Tue Jul 26, 2011 5:56 am
I talked to my buddy today, he is running a 349 CI right now in his Fairlane. He says he can get up to 352 or so with 060 overbore.
If you want to talk to him about building a nice strong stroker 302 for your EB send me a pm and ill get you his number.
Wed Jul 27, 2011 9:40 pm
Well, I thought about the 302 to 347...then found this for $200. Can you guess what's under the blanket? :)
Thu Aug 04, 2011 11:17 am
From the contours of the blanket I'm going to say '96 351W roller block.
Thu Aug 04, 2011 11:58 am
Viper must use "the force".
Thanks for your help Phil. Block and everything look good.
Thu Aug 04, 2011 12:03 pm
Exciting - you don't waste any time. Is it an EFI system? What was it out of?
Thu Aug 04, 2011 1:17 pm
Yes, it came with full EFI but it's the truck version and from what I understand, not well suited to the Bronco.
It's out of a 1996 F350....rumor is it had around 48K miles on it before it was crashed.
Thu Aug 04, 2011 1:18 pm
Sounds like a great findwith such low miles - congrats. I would guess it could be tuned to a Bronco. I think Booger and ZOSO are the John Lingenfelter and Reeves Callaway (GM tuners) of the Mustang world.
Thu Aug 04, 2011 1:29 pm
Thu Aug 04, 2011 1:39 pm
Thu Aug 04, 2011 2:03 pm
That intake is definitely going to be the problem. If'n you are wanting to stick to the EFI (which I don't know why you wouldn't, except for the reasons I am about to lay out), you are going to want to start hunting for a 95 Cobra R or 1st Gen Lightning lower intake manifold and an Explorer/Mustang GT 40 upper intake. As far as I know, those two models of vehicle were the only ones that used the offset lower intake manifold and offset upper intakes. Of course, a complete intake setup from either the Cobra or Lightning will work as well.
Lightning/Cobra R lower
GT40 Upper
I know J.D. is running an EFI 5.8L in his truck. I forget which intakes he has though.
Thu Aug 04, 2011 3:15 pm
So which years cobra/lightning will work to swap everything over?
And I take it cobra/lightning refers to the intakes and not the vehicles they came in right? Sorry, learning here.
Thu Aug 04, 2011 3:58 pm
Something like this...
http://item.mobileweb.ebay.com/viewitem ... 6345416361
And this....
http://item.mobileweb.ebay.com/viewitem ... 4988398702
Or....
http://item.mobileweb.ebay.com/viewitem ... 4176175460
Thu Aug 04, 2011 4:08 pm
Thu Aug 04, 2011 4:15 pm
Thu Aug 04, 2011 4:32 pm
So I take it this upper would work but the lower wouldn't?
http://cosprings.craigslist.org/pts/2471507945.html
Also, can't you get an upper name plate made to indicate "5.8L" etc? Found one..not original but cool.....
http://www.performancepartsinc.com/images/5_8intake.jpg
Thu Aug 04, 2011 7:16 pm
There were some marine 5.8's with a cast iron version of the lightning lower too.
Thu Aug 04, 2011 8:35 pm
Good to know.....I'm looking around. Not many on Craigslist or eBay now.
Any suggetions on a good machine shop to get the basic boring and cleanup done on the block?
Thanks.
Fri Aug 05, 2011 6:01 am
So can the Gt40 upper be from any year?
Fri Aug 05, 2011 6:19 am
I would also check ford racing for this. I would like to do a similar setup with mine someday.
Just an old '71 Fixer Upper
Looking for Power Steering, Disk/power brake conversion parts!!
Fri Aug 05, 2011 7:05 am
Fri Aug 05, 2011 7:53 am
Ok. So I see a lot of GT40 5.0L uppers available. Is there any problem with flow restriction etc for the 351w or larger?
Fri Aug 05, 2011 7:56 am
Fri Aug 05, 2011 8:01 am
33,005,577 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
