www.ColoradoClassicBroncos.com - View topic - intake gasket came out in 4 pcs
It is currently Sun Nov 24, 2024 2:52 pm
Reply to topic  [ 6 posts ]
Post intake gasket came out in 4 pcs
Fel-Pro 1250, 302, Dart Pro 1 Aluminum heads:
I bought a turn-key vehicle and never checked the timing. After a severe overheating mtn. drive, I checked it and found 26 base / 50 total (at 3000rpm). Cranking compression and leakdown are great. But, I still wouldn't have expected this.
Thu Aug 04, 2011 8:52 am
Post Re: intake gasket came out in 4 pcs
I'm far from an engine guy, but over on another popular bronco site, I've seen this topic more than once with regard to fel-pro 1250 gaskets.
here is a link to one thread over there.
http://classicbroncos.com/forums/showth ... light=1250
Seems like they had some years with poor performing gaskets.
Brett
Thu Aug 04, 2011 9:00 am
I had the same issues with the 1250's. I replaced them with the 1250-S gaskets which have a steel core. Been working fine for the last 10K miles or so.
Thu Aug 04, 2011 9:06 am
Well, there's your problem! Thanks for posting this up. I need to do mine sometime soon and might not have caught the issue.
Thu Aug 04, 2011 9:18 am
Thanks for the input. The internet if FULL of crap about 1250 gasket issues, but I imagine there is a nasty-gram about everything on the 'net.
I've got a carb setup, so my intake comes off in about 20 minutes. I already bought a set of the standard 1250's, so I think I'll try it. Fel Pro 1250S3 is a $45 intake gasket.
Thu Aug 04, 2011 10:53 am
This is great info....I will be using the Ss also!
Fri Aug 05, 2011 7:23 pm
Users browsing this forum: No registered users and 19 guests
33,004,634 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
