Register •
FAQ
• Login
It is currently Sun Nov 24, 2024 2:38 pm
[ 4 posts ] |
Mustang/Centech Harness EFI Questions
dsmith01
Joined: Wed Dec 29, 2010 3:50 pm Posts: 215 Images: 0
Okay, been trying to finish up the wiring and I have a few questions. Centech harness is installed and I've started reworking the Mustang harness.
I've created a common ground and wired the power circuits per Ryan's website. I do not know what to do with these wires.
Centech Harness:
IGN PWR COIL+ Choke (I guess this can be removed) Idle Sol Dist Mod
Mustang Harness
Manual Transmission Signal Return (I have an auto...Remove?) Low Oil (Remove?) 12v Start for TFI NDS PIN 30 Ground for PIN 30 (Am I over thinking this one?) Fuel ON (this is coming from the computer. Is it the switch PWR for the fuel relay?)
Also, I only have 2 coil wires coming from the harness but my coil has 4 connections on the pigtail.
_________________ 1972 EB - Fuel Injected 351w, 33s, detroit rear
My Personal Website -
Sun Aug 07, 2011 9:32 am |
Re: Mustang/Centech Harness EFI Questions
I'm not real familiar with the centech labelling. Ign pwr and coil+ sound like the same thing to me. Tell me what they go to and I can figure out what the difference is. You'll need to use one of those to trigger the EFI relays.
Choke, idle solenoid and dist mod wires are not needed but might be useful in the future. Should be 12V in RUN. Either would also work to trigger the relays.
Remove the low oil wire. It works with the mustang instrument cluster not the ECM.
I would wire the pin #46/pin #30/NSS like the RJM harness with a pluggable jumper. For example, put a male connector on the pin #46 wire and female connectors on the pin #30 wire and another wire going to the "S" terminal of the starter solenoid. This would allow you to use either a manual or auto ECM by simply swapping the connector. Auto ECM connects pin #46 to "S", manual ECM connects it to pin #30.
What is fuel ON? Pin #22 in the ECM is a ground that turns on the fuel pump relay.
TFI START signal is pin #3 of TFI connector. It gets connected to "S" terminal of starter solenoid also.
Sun Aug 07, 2011 11:44 am |
dsmith01
Sun Aug 07, 2011 1:59 pm |
Ok. You can use the coil+ for TFI start. In fact you can even leave it on the "I" terminal if you want. "I" and "S" see the same voltage at the same time.
Sun Aug 07, 2011 3:30 pm |
[ 4 posts ] |
Users browsing this forum: No registered users and 23 guests |
