Register •
FAQ
• Login
It is currently Sun Nov 24, 2024 3:27 pm
[ 3 posts ] |
4wd slugs sticking in hub
austinbrose
So I did my chevy disc brake conversion and my factory lock outs aren't working on one side. The splined/toothed slug doesn't go in far enough to disengage on one side. Thoughts? Think it just needs cleaned and scrubbed and re-greased? Or is my new(used) hub deformed? Thanks guys.
Wed Aug 17, 2011 5:00 pm |
Re: 4wd slugs sticking in hub
I know on mine they had to grind the outside of the hub just enough to get the snap ring on the axle shaft. That might get you a little more clearance.
Wed Aug 17, 2011 7:30 pm |
Clean it up real good, get some good white lithium grease (not the spray) and put it back together with that. Remember, less is more. Often times, they are over-greased and the vacuum of the grease is like you slogging thru a march in flip-flops. It's hard to pull your foot out of the muck! Anyway, just a light coat of grease on all surfaces and you should be good.
Mon Aug 22, 2011 11:23 am |
[ 3 posts ] |
Users browsing this forum: No registered users and 21 guests |
