www.ColoradoClassicBroncos.com - View topic - Motorcraft Jet Sizes
It is currently Sun Nov 24, 2024 3:28 pm
Reply to topic  [ 4 posts ]
Post Motorcraft Jet Sizes
So I'm going to be moving back to the midwest and will need new jets for the drive and the arrival. I was wondering if anyone had any idea what size jets to use at what altitude? Runs great now at 7,000 plus, but I know even in Denver it doesn't run well. Thanks for any help.
Mon Aug 22, 2011 5:26 pm
Post Re: Motorcraft Jet Sizes
Thats a hard question to answer, you need to know what size jets are in there already, usually 2 steps up then run again and see how it performs and if it is too rich or lean.
Tue Aug 23, 2011 4:45 pm
Thanks for the reply. I figured there would be a manual that someone would have. I'm used to snowmobiles and they have manuals that tell you to change jets with temperature!
Fri Aug 26, 2011 7:02 am
Austin, Try this site. It is more along the lines with rebuilding the carb but has alot of good info. http://www.therangerstation.com/tech_li ... 0_carb.pdf
I need to rejet my 2150 for altitude above 9k also. There are several people on ebay who have the jets, You need to know what you have first. Good luck and let us know what you find out as it will help the rest of us. Jayson
74, MONEY EATER
Fri Aug 26, 2011 1:03 pm
Users browsing this forum: No registered users and 25 guests
33,005,374 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
