www.ColoradoClassicBroncos.com - View topic - Hyd Roller camshaft with 114 / 116 LSA?
It is currently Sun Nov 24, 2024 6:41 pm
Reply to topic  [ 5 posts ]
Post Hyd Roller camshaft with 114 / 116 LSA?
Why can't you find HR sticks with wider lobe separation? And, I'd like higher lift with short duration.
I have way too much camshaft.... i'm betting on 110 LSA with 235 duration at .050 considering the 11" idle vacuum and the way it pulls above 5000 rpm. I want something much closer to stock for a daily driver, but I have 195cc Dart Pro 1's set-up for .620 max valve lift. It would be nice to take advantage of the lift potential but retain a reasonable idle / low speed torque.
Who makes one?
Tue Jan 10, 2012 3:00 pm
Post Re: Hyd Roller camshaft with 114 / 116 LSA?
Tue Jan 10, 2012 4:23 pm
Give Scott a call at CAM Research. He is the master....and will build you a custom cam for the same (or less) that you can get the off-the-shelf models.
http://www.camresearchcorp.com/
They are local in Englewood.
Tue Jan 10, 2012 5:44 pm
I'll look into a custom cams, but I was hoping to avoid re-inventing the wheel. I have enough projects going on right now. I most likely need a Retrofit cam since I have a '71 block and I did find a few mild RF cams. Howards has an extreme torque series, it just took a lot more looking since hot rod cams are much more popular than truck stuff.....
I @ .050 E @ .050 I ADV E ADV I LIFT E LIFT LSA
LUNATI 209 213 270 279 445 477 112
HOWRDS 207 213 260 266 480 498 112
HOWRDS 213 219 266 272 517 517 112
COMP C 205 205 260 260 510 510 110
HOWRDS 209 215 262 268 496 501 110
Thu Jan 12, 2012 10:48 am
Not reinventing anything....5 min on the phone with Scott telling him your plans and he'll have the specs done on your cam. And it will be perfectly matched to your engine and usage.....and for the same $ as off the shelf.
Another option is Woody at www.fordstrokers.com. He'll have one done up in billet for about the same $.
Sun Jan 15, 2012 8:08 am
33,011,038 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
