www.ColoradoClassicBroncos.com - View topic - Dumb question....
It is currently Sun Nov 24, 2024 7:49 pm
Reply to topic  [ 6 posts ]
 Dumb question....
Post Dumb question....
So the axle code on my '74 says A58. Anyone know what gears I might possibly have? I only found that A5's are 4.11s.
After a little research I found that it is also an HD. Is it safe to assume the HD means heavy duty? or am I way off base here?
Thanks.
Mike
Sat Feb 25, 2012 9:36 pm
Post Re: Dumb question....
Are you certain it doesn't say A5J? A5 would indicate a 9" with 4:11 gears and LS. I'm not sure what an 8 would indicate, a J would be PS on the Dana 44.
Sat Feb 25, 2012 10:03 pm
A5 is 4.11 limited slip in the 3300 lb axle.
8 is front limited slip without power steering.
Sun Feb 26, 2012 1:04 am
Thank you guys.... I appreciate the help.
Any one have a guess on the "HD" thing?
Mike
Sun Feb 26, 2012 9:35 am
The 3300 lb capacity axle is heavy duty. It was required with the 4900 lb GVWR (U152) and optional with the 4500 lb GVWR (U151).
Sun Feb 26, 2012 11:47 am
Thank you Viperwolf.
Sun Feb 26, 2012 5:16 pm
33,012,826 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
