Register •
FAQ
• Login
It is currently Sun Nov 24, 2024 8:05 pm
[ 5 posts ] |
rdanford
Joined: Wed Sep 29, 2010 8:12 pm Posts: 169 Location: Windsor
Rear Axle Parts
Guys...Going to be pulling the rear axles here in the next couple weekd when I pull the 3rd for Dan to install 4.10s. What bearings and seals do you recommend for replacement...probably have 200k miles on the stock parts?
_________________ Royce 1977 Bronco...EFI, ViperBuilt C4, PS, PB, cut with 33's - Rebuild coming 1987 Porsche 951...LS1 swap - SOLD 2006 4Runner V8 Sport Edition 1998 4Runner...DD with 333k and counting
Thu Mar 01, 2012 8:02 am |
Re: Rear Axle Parts
I would replace carrier bearings and the axle bearings and seals.
The outer axle seal can be a biotch to remove. I think I screwed up the bore in my axle tube when I did mine.
I have a nice set of seal drivers if you want to use them. But they are also available for rent at most parts stores too.
Thu Mar 01, 2012 8:33 am |
rdanford
Re: Rear Axle Parts
Got the bearings and seals coming from TBP...Dan, pressing them would be another great help!
Fri Mar 02, 2012 2:24 pm |
Re: Rear Axle Parts
You're gonna love the 4.10's.
Fri Mar 02, 2012 2:38 pm |
rdanford
Re: Rear Axle Parts
I can't wait...should feel it for sure!
Fri Mar 02, 2012 2:44 pm |
[ 5 posts ] |
Users browsing this forum: No registered users and 16 guests |
