www.ColoradoClassicBroncos.com - View topic - 2000 F-250 wont run
It is currently Sun Nov 24, 2024 8:39 pm
Reply to topic  [ 18 posts ]
 2000 F-250 wont run
Post 2000 F-250 wont run
Hi guys, I have a 2000 F-250 with the v-10. the other day I went to go start it and it started then shut off about 3-5 seconds later. I starts runs at 1100ish RPM then shoots up to 1500ish then shuts down. I can do this 5-6 time in a row and it does the same thing every time. Almost seems like a anti theft type thing but im not sure. If anyone has any ideas or knows of anyone that could help i would very much appreciate it.
Mon Apr 30, 2012 6:08 pm
Unhook your battery/batteries for 10 minutes. Should clear any mode it's in. Also is SES light coming on?
Mon Apr 30, 2012 7:45 pm
Post Re: 2000 F-250 wont run
That didn't work. I'm going to replace the Idle air control valve and see if that works.
Mon Apr 30, 2012 8:46 pm
Find someone with a code reader. That way you can concentrate on one area and save you some money. Anyone with an SCT programmer can do it, you don't need a fancy snap-on.
Mon Apr 30, 2012 8:59 pm
So a new IAC didn't work. When I hooked up the scanner there were no codes to read. I don't know where to go from here.
Tue May 01, 2012 4:34 pm
Fuel filter. Check fuel pressure.
Tue May 01, 2012 5:00 pm
It's a V-10 you say? you are probably out of gas. :laughing2:
Wed May 02, 2012 7:06 am
Fuel pump would be my guess
Wed May 02, 2012 8:02 am
Fuel pump? The engine shooting to 1500rpm's could be a bi-product of the engine starving.
Wed May 02, 2012 8:24 am
You could find the fuel pump (maybe on the frame rail or inside the tank) have someone cycle the key on and you listen for it. If nothing, could be the relay or maybe even a blown fuse.
Wed May 02, 2012 8:26 am
Wed May 02, 2012 8:37 am
Wed May 02, 2012 9:30 am
Well after all that it was the mass airflow sensor.
Thanks for all the ideas guys!
Wed May 02, 2012 6:32 pm
Wed May 02, 2012 7:48 pm
Yea i pulled it out and cleaned it real good and put it back in and all was good.
Wed May 02, 2012 8:21 pm
You running a K&N?
Wed May 02, 2012 8:40 pm
A knock off K&N, that's what it came with when I bought the truck. Now that everything works it's time to sell it.
Wed May 02, 2012 9:15 pm
Oh, ok. If you were going to keep it, I'd find a dry-flow filter. Oiled filters cause some bad problems if you don't oil them exactly right.
Thu May 03, 2012 7:20 am
33,014,293 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
