It is currently Sun Nov 24, 2024 10:53 pm
[ 8 posts ] |
3 speed manual wont go into 2-3
socofn
Joined: Sat Apr 02, 2011 11:52 am Posts: 204 Images: 0 Location: Pueblo County
Finally got everything back in and now it won't go into 2-3. It a 3speed on the collum and the linkage is free. I can move 1-reverse by hand but 2-3 wont budge and I do not want to put to much pressure on it. Suggestion are greatly apperciated. JP
_________________ 74, MONEY EATER
Sat Jun 16, 2012 6:44 am |
If your trans is toast, let me know. I have two organ donors in the garage you can pick apart.
Sat Jun 16, 2012 12:32 pm |
Re: 3 speed manual wont go into 2-3
You just might have to take aka up on that offer.
Sat Jun 16, 2012 8:17 pm |
socofn
I hope it isn't as it is the one I just got from airbur attached to a 302 that was working. I have not had time to mess with it since friday but if anyone has any ideas what I can do to figure this out, your input is greatly apperciated. Thanks JP
Sun Jun 17, 2012 5:59 pm |
Well, my first suggestion would have been to pull the top cover and have a look see at what is hanging up.
Just for giggles, you are manipulating the shift levers in a R-N-1/3-N-2 fashion, correct? Middle position being neutral, gears to either side.
Sun Jun 17, 2012 6:21 pm |
socofn
On the shift levers it goes freely into r-n-1 and will not move at all into 2-n-3. Pulling the top cover is going to be a PIA as it is already installed!!! I will do what I need to tho to get it back up and runnin. Thanks JP
Sun Jun 17, 2012 9:21 pm |
airbur
What did you do to my tranny?! I had no prob shifting it the day I took the video for you.....ran it around the city a bit to make sure everything was in good working order before I pulled it.
Maybe an issue with how the clutch linkage is setup?
Mon Jun 25, 2012 9:13 pm |
socofn
Got it figured out. Thanks JP
Tue Jun 26, 2012 8:50 am |
[ 8 posts ] |
Users browsing this forum: No registered users and 31 guests |
