Register •
FAQ
• Login
It is currently Sun Nov 24, 2024 10:50 pm
[ 6 posts ] |
jbregar
Joined: Thu Jun 07, 2012 10:10 pm Posts: 94 Location: Pueblo West, CO
Power Steering Hose
Okay, so I have the Exploder motor and the Exploder power steering pump. I have a stock Bronco power steering box. I'm also power steering retarded.
For the pressure side, I think I'm going to do the -6AN adapters and hoses mentioned in the Explorer serpentine swap on ClassicBroncos.com. Seems quite straightforward.
The return side is a little more confusing because the writeup kind of just assumes you know what you're doing there. Can I take a stock Bronco power steering return line, cut the pump-end fitting off (if there even is one, I'm not sure) and then hook it to the return barb on the Explorer reservoir?
I'd imagine that'd be a decent way to do it, but I wanted to make sure before I bugger something up.
_________________ 1966 Bronco (Aug. 1965 production date), 5.0L Explorer EFI, 33x12.50 BFG AT
Fri Jul 20, 2012 2:52 pm |
Re: Power Steering Hose
Only use the Lee adapter mentioned in the article. The other option is reportedly very troublesome. Return line just goes straight to reservoir but its a good idea to run it through a cooler of some type first.
Fri Jul 20, 2012 3:01 pm |
jbregar
Yeah. I ordered the Lee adapter. Also got the steel adapter for the box end rather than aluminum.
I'll run it through a cooler. I think my champion radiator actually has a tranny cooler tube in it. That might work to cool the PS fluid since I'm using a manual tranny.
Fri Jul 20, 2012 6:24 pm |
The radiator cooler is a fine idea.
Fri Jul 20, 2012 7:12 pm |
I thought about doing the same thing, but my champion radiator has a little bitty fitting on it. I wasn't sure it would flow enough. It'd make me happy if I were wrong, though, since I'm hoping someday to install the hydroboost unit that I've had for at least 9 months.
Sun Jul 22, 2012 9:44 pm |
jbregar
Yeah... the champion radiator fittings are incredibly tiny. I didn't think about that. They're what? Maybe 1/4NPT?
Mon Jul 23, 2012 1:38 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 27 guests |
