[phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4794: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4796: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4797: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4798: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) www.ColoradoClassicBroncos.com - View topic - Cleaning up a hydroboost
I'm finally getting around to installing my hydroboost unit, but need to clean and paint it first. Anyone know if there is anything inside them that I need to be careful with while doing this? I'm figuring on plugging the ports, then using Simple Green to start, but don't want to mess it up if I have to break out the solvents.
Sun Aug 05, 2012 8:29 pm
sbolt19
Re: Cleaning up a hydroboost
None that can't handle a dunk tank. When I did mine, it was covered in grease and I dropped in the solvent tank and it has always worked fine.
Users browsing this forum: No registered users and 14 guests
