www.ColoradoClassicBroncos.com - View topic - Shear strength and rear seat mounting
It is currently Mon Nov 25, 2024 1:51 am
Reply to topic  [ 6 posts ]
Post Shear strength and rear seat mounting
Recently purchased a trailmax fold and tumble seat and am toying with an idea to install it using a track system from MACS which might work but before I go too far I wanted to ask about the strength.
The studs that I'm looking at would allow for ease of removing are rated for a shear strength of 2000lbs lateral. There would be 4 studs in use. Is this strong enough for a rear seat application in case of an accident?
http://www.macscustomtiedowns.com/category/VersaTie
I was planning on using 4 3/8" grade 8 bolts through the bed with large flat washers for backing but like to idea of quick removal and tie down capability of the MAC system if it will be safe enough.
Thanks
Brett
Thu May 09, 2013 6:03 am
Post Re: Shear strength and rear seat mounting
The bolts and brackets are strong enough, though I'm not a safety engineer, your problem is the mounting. The factory positions are reinforced with a thicker than sheet metal channel & large welded nuts. By just bolting through the sheet metal you are running the risk off pulling the hardware right through the sheet metal if a major force was applied. I'd try two options; use the factory mounting holes or recreate the strength in the new mounting locations.
Thu May 09, 2013 6:16 am
Thu May 09, 2013 6:25 am
Thanks all, I ordered up a set of tracks and mounting studs. Pretty cool place, good customer service. I called this afternoon at 3:00 and the parts have shipped via Fedx already.
Brett
Thu May 09, 2013 7:16 pm
Do post pictures! I wouldn't mind having something like that too. A 2 minute operation to install or remove the rear seat!
Fri May 10, 2013 4:17 am
Images: 2
I would think in an accident the bolts only hold the mass of the seat. The belts are what need to hold passengers.
Sat May 11, 2013 9:57 pm
Users browsing this forum: No registered users and 14 guests
33,022,327 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
