www.ColoradoClassicBroncos.com - View topic - Oops! Power steering leak when trying to adjust belt
It is currently Mon Nov 25, 2024 1:59 am
Reply to topic  [ 3 posts ]
Post Oops! Power steering leak when trying to adjust belt
I was going to try to tighten my PS belt to reduce the squeal I was getting when turning. So I loosened up the bolt on the left of the reservoir mount to try to tighten.
Then suddenly the PS fluid started to drain. I re-tightened and it continued to drain. Yikes. Did I damage something?
I'm looking for ideas and suggestions. I have no real idea what my next step ought to be. Thanks
Sun May 26, 2013 1:01 pm
Post Re: Oops! Power steering leak when trying to adjust belt
Sounds like you have a loose hose maybe? Take a picture of your setup and the bolt you tried to take out.
Sun May 26, 2013 1:17 pm
Could be the pulley shaft seal has given up the ghost.
Sun May 26, 2013 4:16 pm
Users browsing this forum: No registered users and 19 guests
33,022,719 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
