www.ColoradoClassicBroncos.com - View topic - EFI fuel hose
It is currently Mon Nov 25, 2024 3:59 am
Reply to topic  [ 7 posts ]
 EFI fuel hose
Post EFI fuel hose
Is there any reason whey I cant run regular fuel line for my return line or do i have to run EFI rated?
Thu Jan 02, 2014 2:16 pm
Post Re: EFI fuel hose
I think its ok cause its not high pressure on the return side.
Thu Jan 02, 2014 4:23 pm
Yes run regular hose pre high pressure pump and on the return line. That high pressure stuff is expensive!
Thu Jan 02, 2014 5:13 pm
Yes it is, that's why I ask. So I will run it from the tank to LP to accumulator then to the HP and also the return. Great will save a lot of money.
Thu Jan 02, 2014 5:18 pm
I think your entire supply line has to run in EFI line, but return lines don't have to. I'd have to go out and check mine to see if that is what I did, but if memory serves me, the standard line will collapse under the pressure of a HP pump.
Fri Jan 03, 2014 12:54 pm
i have EFI rated line from the HP pump to the motor so Im good there.
Fri Jan 03, 2014 5:16 pm
I've been running low pressure carb fuel line from the tank to the LP pump, to the accumulator, to the HP pump for 2 years now with no problems.
Fri Jan 03, 2014 6:07 pm
33,026,860 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
