It is currently Mon Nov 25, 2024 5:38 am
[ 12 posts ] |
Boulderbronc
Joined: Thu Dec 23, 2010 11:28 pm Posts: 40 Images: 0 Location: Longmont
94 Port injected 5.8L
I want to put a 5.8L port injected in my 75 bronco, has anybody done this? or can it be done?
Looking to see if it is the wrong motor. I got it from a 94 F250 w/auto trans.
Thu Jan 16, 2014 10:40 pm |
Re: 94 Port injected 5.8L
Calling RJLougee and Jesus_man!
Thu Jan 16, 2014 11:27 pm |
Cant use the factory truck upper. BCB has an adapter to mate the mustang upper to the truck lower. Or spend big $$$$ and if you can find one a 5.8 lightning lower that will allow you to put a gt40 mustang upper on it. Than you use a mustang computer and a harness.
Sun Jan 19, 2014 5:59 pm |
I've got a BCB adapter, truck lower and Mustang upper that I could be talked out of.
Sun Jan 19, 2014 7:13 pm |
Yes, mine is out of a '94. Roller cam, GT40 intake, MAF etc. Been a great motor, especially since it came from the junkyard. jlougee installed it.
Tue Jan 21, 2014 9:18 am |
Error404
Joined: Fri Aug 16, 2013 8:33 am Posts: 92 Location: COLORADO SPRINGS
hey justin, what do you gotta have for you adapter and intake parts? Dont need either upper or lower as I have both and a 351w but if your getting rid of at a package price?
_________________ 1996 bronco 4bt sas . 1972 bronco 10k mi no motor no trans..unfortunately rolled in 1973. Left for me to bring back from the dead.
Wed Jan 22, 2014 2:02 pm |
PM sent.
Wed Jan 22, 2014 2:10 pm |
RJLougee
Wed Feb 05, 2014 8:37 pm |
Yep it has been a great motor. It's time for some refreshing, but I have been happy with it. Even survived a flop.
Thu Feb 06, 2014 2:02 am |
Thu Feb 06, 2014 2:54 pm |
RJLougee
Fri Feb 14, 2014 4:59 pm |
RJLougee
Fri Feb 14, 2014 5:03 pm |
[ 12 posts ] |
Users browsing this forum: No registered users and 25 guests |
