It is currently Mon Nov 25, 2024 5:31 am
[ 11 posts ] |
Lila76
Joined: Mon Oct 24, 2011 12:02 pm Posts: 111 Images: 0 Location: Aurora, CO
No power anywhere!!!!!!
I am in the final assembly of the 72 restoration and have everything wired up and I have no power anywhere. Ignition key does not work no lights ect.... I have checked and replaced all fuses hew voltage regulator, tried a few different ones as well. I'm sure I'm missing something stupid. Any ideas? I was going to activate the viper wolf signal to help but lost all contacts in my phone. I really need to get this beast fired up soon and on the road. Beers to anyone that can help out with advice or a donation of time.
_________________ What did you learn?
Mon Feb 03, 2014 8:05 pm |
Re: No power anywhere!!!!!!
Good voltage at the battery? Good voltage on the side of the starter relay that the battery runs to?
Mon Feb 03, 2014 8:14 pm |
Lila76
The motor cranks when the solenoid is bypassed. No power after the solenoid but that is new as well.
Mon Feb 03, 2014 8:18 pm |
This is on a 72 as well. From left to right. Key off 1: 12v 2: 0v 3: 0v 4: 0v Key in run position 1: 12v 2: 0.05v 3: 12v 4: 0v I pulled those number 5 minutes ago. Seeing something similar?
Mon Feb 03, 2014 8:44 pm |
Lila76
Looks identical.
Mon Feb 03, 2014 8:48 pm |
Have you got a multimeter to test those numbers?
Mon Feb 03, 2014 8:52 pm |
Lila76
1 -12. Key on and off 2 -0. 3 -0. 4 -0.
Mon Feb 03, 2014 9:36 pm |
Moab Mike
Fusible link
Mon Feb 03, 2014 9:39 pm |
Mon Feb 03, 2014 10:34 pm |
Lila76
It appears my wire is blue. I'll check it's connections in the morning. Thanks for the help
Tue Feb 04, 2014 8:58 pm |
Moab Mike
You can check for voltage at both ends and then pierce the insulation just before/after the fuse to verify. Junkyards are full of "spares" for little to nothing.
Tue Feb 04, 2014 9:48 pm |
[ 11 posts ] |
Users browsing this forum: No registered users and 23 guests |
