www.ColoradoClassicBroncos.com - View topic - Why won't my stinger lift ?
It is currently Mon Nov 25, 2024 5:42 am
Reply to topic  [ 16 posts ]
Post Why won't my stinger lift ?
So I have been having fun using my (new to me) Meyer snow plow.
The pump leaks a little but seems to work pretty good when it is warm out.
Last couple of days as the temps have dropped, not so much.
Yesterday I had to cycle it up and down and side to side a few times to get it to function consistently. I assume that doing this warmed the Meyer approved hydrualic oil up enough for sufficient flow.
Today it is even colder and I couldn't get the stinger to lift the plow off the ground even after making sure it was no longer frozen in place.
I could get it to move side to side a couple times but then it quit doing that.
So, is my flow not laminar enough or is my flow just to turbulent (calling Justin !) or should I just rebuild this sumbitch and see what happens ?
Tue Feb 04, 2014 7:31 pm
Post Re: Why won't my stinger lift ?
Here's the fix, it comes with two spare pumps too.
http://denver.craigslist.org/pts/4285498341.html
You may have cracked the seals from being both old and cold or they are deformed. I strongly recommend a rebuild for the pump.
Tue Feb 04, 2014 7:36 pm
Tue Feb 04, 2014 7:41 pm
Wouldn't hurt to throw some seals in your rams too.
Maybe it leaked too much.
Tue Feb 04, 2014 7:44 pm
ordered master rebuild kit for the pump and gotta find the cylender seals now
Tue Feb 04, 2014 7:46 pm
Rocket Seals in Denver is were we get some of our cylinder reseal kits.
Tue Feb 04, 2014 9:01 pm
Still waiting for a reply from Shawn on those dip stick zip ties..... just sayin.
Wed Feb 05, 2014 9:33 am
I hate being so predickable.
It has been difficult not responding to all you guys talking about "ram"ing your "hoses" and breaking your "seals". But make sure you pull out your "dipstick" and check the "leakage". I'm surprised nobody has suggested any shrinkage in this cold weather or the right kind of lubricant. Maybe, just maybe if you drop a couple of those little blue pills Angie gives you into the pump, your stinger will lift.
....oh....that's better.
Wed Feb 05, 2014 12:00 pm
It's only cold in far northern CO. Sunny and warm down here.
Wed Feb 05, 2014 12:15 pm
Wed Feb 12, 2014 11:33 am
some how cured itself not that it is warmer
I don't get it
Wed Feb 12, 2014 11:35 am
Pull the motor off and check / clean the inlet screen when they get dirty they don't like to work
Wed Feb 12, 2014 3:41 pm
our old plow truck at work is the same way when its cold. The fluid might have a little moisture in it so it's freezing.
Wed Feb 12, 2014 5:47 pm
33,029,208 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
