It is currently Fri Nov 22, 2024 5:05 pm
[ 25 posts ] |
TOOLMAN
Injector Rebuild
Any of you fellas have information or a link as to where to purchase the injector rebuild kits? I've seen a few online and was wondering which place was the best to deal with.
Wed Dec 10, 2014 1:09 pm |
Moab Mike
Re: Injector Rebuild
PM Gregg, he has rebuilt several sets of injectors. I don't know where he gets his rebuild kits.
Wed Dec 10, 2014 7:10 pm |
Bought a kit from here http://www.mrinjector.us/ find your injectors or all and tell them what you have, think it was $30 for the kit.... i used carb cleaner initially to soak them and then blew them out with a compressor... they come with great directions.
Wed Dec 10, 2014 10:26 pm |
TOOLMAN
Thanks for the feedback, fellas.
I have been eyeing the Mr. Injector site. There's also a guy on ebay that sells rebuild kits (for about $12 cheaper), but can't seem to find the correct ones.
Thu Dec 11, 2014 9:02 am |
Gregg
I bought a couple kits from RJM Injection for $20 each. The first kit was sent fine but the second kit took some calling, e-mailing, and searching before it finally arrived at my door. Looks like they've been having some customer service problems lately so it may not be a safe bet. However, the product was good. Mike made a cool clip system that opens the injector with a 9V battery. It makes it easier to flush out the injector with a compressor. All you need is a 9V battery, solder, and a pair of nipple clamps.
Thu Dec 11, 2014 9:59 am |
Rjm is closed I think
Thu Dec 11, 2014 2:34 pm |
BroncoMasochist
Joined: Wed Sep 10, 2014 9:26 pm Posts: 21 Location: Roggen, Colorado
I bought the rebuild kits at NAPA, have also bought some on ebay.
_________________ .....because the pleasure of owning a Bronco comes with the pain of owning a Bronco.
Sun Dec 14, 2014 6:51 pm |
Jason-- did you ever find a source for these?
Fri Jan 23, 2015 11:37 am |
TOOLMAN
Fri Jan 23, 2015 12:50 pm |
Fri Jan 23, 2015 1:24 pm |
TOOLMAN
Thanks for the input, Viper.
Mon Jan 26, 2015 11:39 am |
While I have mine apart, I have considered getting them rebuilt. I was leaning towards sending them in so that they can be utlrasonic'd and cleaned. Any opinions on rebuilding them yourself vs. just sending them in?
Mon Jan 26, 2015 11:50 am |
Gregg
Im pretty cheap so I did it myself. I didn't have any problems and the instructions were pretty straight forward.
Tue Jan 27, 2015 9:08 am |
Tue Jan 27, 2015 9:38 am |
Did my own 3 years ago. Very easy.
Tue Jan 27, 2015 1:22 pm |
Quick bump on this thread. Which rebuild kit do the 17lb injectors in the '99 Explorer take? Bosch EV14?
Sat Mar 18, 2017 5:47 pm |
TOOLMAN
Not sure Justin. Eck and I went in together to get two sets to get the cost down and he ordered them. Maybe he will pipe in. I think we got the orange ones which if I remember are #19. I think you're looking for the beige ones and I do believe they are Bosch. You're going return-less, correct?
Mon Mar 20, 2017 6:57 am |
That's the plan.
Mon Mar 20, 2017 6:59 am |
I ordered Toolman's and I's from a guy off eBay. There are all sorts of these things on there. If you're looking to rebuild yours, I found this on there: http://m.ebay.com/itm/V8-Ford-5-0-Fuel- ... Ciid%253A9You could probably email the seller to confirm fitment.
Mon Mar 20, 2017 9:07 am |
I shot Mr. Injector an email to confirm fitment. Here's the response: Thanks for your interest in our products. Here is a link to the kit for your application: http://www.mrinjectorparts.com/store/p1 ... s_002.htmlOur kits come with the standard universal Bosch caps. If you would like the OEM cone style caps that come on your injectors write "supply cone OEM caps" in the notes to seller at check out and I'll supply both at no extra charge. Bill Bill Johnson / Mr Injector 6280 N Government Way Unit 4 Dalton Gardens, Idaho 83815
Tue Mar 21, 2017 10:12 pm |
"No extra charge" sounds like the right price! May be unnecessary but I'd be tempted to buy a small, cheap ultrasonic cleaner off eBay to run each injector through as well to clean everything up nice.
Tue Mar 21, 2017 11:09 pm |
I've been kicking that around. Harbor freight's is well reviewed.
Tue Mar 21, 2017 11:48 pm |
Wed Mar 22, 2017 8:59 am |
What procedure you guys have been using to clean the injectors out?
Tue Apr 04, 2017 5:30 pm |
Disassembling, then a good soak in a carb / EFI cleaner or ultrasonic bath, followed by 9 volt battery & compressed air.
Wed Apr 05, 2017 7:11 am |
[ 25 posts ] |
Users browsing this forum: No registered users and 33 guests |
