www.ColoradoClassicBroncos.com - View topic - ZF5 Swap
It is currently Sat Nov 23, 2024 1:07 am
Reply to topic  [ 26 posts ]
 ZF5 Swap
Post ZF5 Swap
The ZF5 fairy dropped off a transmission yesterday and I'd like to start sourcing the stuff I need. After breaking out the google-fu, it looks like I'll need:
-A custom crossmember
-Dana 20 adapter
-Clutch master cylinder
-Clutch slave cylinder
-Clutch hose
-Flywheel and clutch (as long as I've got it out).
-Brake pedal to swap for the current clutch pedal
Couple of other questions:
-I'll probably replace the clutch and flywheel while I've got everything apart. As long as I'm putting in a new flywheel can I swap for one matches the weight of my Explorer front dress and install the serp stuff at the same time?
-Any difference between the adapters sold by the various vendors? I'm assuming they're all the Advance Adapters part.
What am I missing? Anything else I should know about the swap?
Tue Sep 29, 2015 10:02 pm
Post Re: ZF5 Swap
While you're making a custom crossmember, just make 2.
Tue Sep 29, 2015 10:16 pm
Post Re: ZF5 Swap
Can do! Mine may have some added features, but they're not hard to do.
Tue Sep 29, 2015 11:14 pm
Post Re: ZF5 Swap
Tue Sep 29, 2015 11:39 pm
Post Re: ZF5 Swap
Don't skimp on the Slave cylinder. I bought one from a chain parts store because I needed it in a pinch and it lasted a year...Not a fund job to do!
You've seen my cross-member? Pretty sure it's obvious I'm quite proud of it.
Wed Sep 30, 2015 12:34 am
Post Re: ZF5 Swap
Wed Sep 30, 2015 5:49 am
Post Re: ZF5 Swap
Do you have a body lift?
Wed Sep 30, 2015 6:24 am
Post Re: ZF5 Swap
Wed Sep 30, 2015 8:43 am
Post Re: ZF5 Swap
Gotcha, much appreciated.
Wed Sep 30, 2015 11:29 am
Post Re: ZF5 Swap
When I had my engine apart, I had the machine shop rebalance the crank so that standard 50oz. components could be used. A lot easier to replace those than a crank down the road. If you are looking to just bolt on to your current motor, send the balancer to damper dudes.
Wed Sep 30, 2015 11:52 am
Post Re: ZF5 Swap
Wed Sep 30, 2015 2:47 pm
Post Re: ZF5 Swap
Sure. Once I mock up mine a few more will be easy. I bent up Landshark's and will probably do something similar for mine with the addition of tabs for a skid plate.
Wed Sep 30, 2015 7:09 pm
Post Re: ZF5 Swap
Me too Iguana!
Wed Sep 30, 2015 7:15 pm
Post Re: ZF5 Swap
Sorry Justin. I was just being a smart ass, but now it appears you are too far in.
Wed Sep 30, 2015 8:22 pm
Post Re: ZF5 Swap
What they don't know is that they'll be $6,000 each.
Nah, we can work something out. I really might knock out a bunch of these to sell if I can figure good design that works well and isn't nuts to make.
Wed Sep 30, 2015 9:01 pm
Post Re: ZF5 Swap
Bump for a quick transmission moron question. I'm working on ordering some of the parts to install this beast. I should get a throwout bearing for ZF's donor, not an EB, correct? I'm planning to run an EB clutch. Also, should I pick up a pilot bearing as well? This is my first trans swap, so I've got no idea what I'm doing.
Tue Dec 01, 2015 10:46 am
Post Re: ZF5 Swap
Tue Dec 01, 2015 11:16 am
Post Re: ZF5 Swap
No, no shifter. I'll need to hit the junkyard for one. Thanks for the info, that was exactly what I needed.
Tue Dec 01, 2015 12:13 pm
Post ZF5 Swap
Do you just need the handle or the whole shift fork that's mounted to the top of the Trans?
Tue Dec 01, 2015 12:24 pm
Post Re: ZF5 Swap
Just the handle. Was going to grab a boot as well, but that's flexible.
Tue Dec 01, 2015 1:39 pm
Post Re: ZF5 Swap
i should have and extra of both the handle and boot.
Tue Dec 01, 2015 2:05 pm
Post Re: ZF5 Swap
Replace the pilot bearing now. Cheap insurance. If it fails it can trash the input shaft.
Tue Dec 01, 2015 4:07 pm
Post Re: ZF5 Swap
Chris, sweet, thanks! Rob, that's definitely the plan. The only wear item I'm not putting in new might be the clutch if my existing one is in good shape.
Tue Dec 01, 2015 11:18 pm
Post Re: ZF5 Swap
Wed Dec 02, 2015 5:57 pm
Post Re: ZF5 Swap
i should be around this weekend Justin if you want to swap parts
Wed Dec 02, 2015 10:01 pm
Post Re: ZF5 Swap
Awesome, thanks!
Wed Dec 02, 2015 10:46 pm
Users browsing this forum: No registered users and 46 guests
32,963,301 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
