www.ColoradoClassicBroncos.com - View topic - Rear Driveshaft Question
It is currently Sat Nov 23, 2024 1:05 am
Reply to topic  [ 49 posts ]  Go to page 1, 2  Next
Images: 14
Post Rear Driveshaft Question
I have a 3.5" lift, 11 pack of leaf springs in the rear and I also had a 1" aluminum block tucked in there.
I just moved the rear axle back 1" so the tires won't rub. (Uncut)
With the leaf springs, block, and 1" relocation, the driveshaft is simply too short. When the body goes up and the tires go down, the driveshaft comes undone.
I went back in and removed the 1" blocks but I liked the stance and want them back, So...
Are there any make/model years of vehicles that I can steal a longer direct fit shaft from?
Or,
Are there any vehicles with a longer shaft or slip shaft or ideally just a longer slip yolk for?
Pic is just for reference, it's not mine.
Thanks again!
Sat Dec 26, 2015 12:35 am
Post Re: Rear Driveshaft Question
I don't know of any, but am in the same boat you are. My plan is to have a driveshaft shop re-tube the it to make it a little longer.
So many shaft jokes....
Sat Dec 26, 2015 1:54 am
a retube and balance is pretty cheap at most places. put the axle back and measure between the yokes. Give the shop that length and your drive shaft. they will make it right.
Sat Dec 26, 2015 8:14 am
I got a front driveshaft out of a '94 explorer. Same u-joints and CV joint, just smaller diameter tubing. I don't remember the original length but it's probably close.
Sat Dec 26, 2015 10:33 am
Explorer front drive is 30" compressed ,center to center on u-joints
Sat Dec 26, 2015 12:21 pm
Images: 14
Thanks Viper and J,
On a flat and level surface, I measured mine from the longest U joint Center end to end and it was 35 3/4 inches.
Jay, if yours is still handy, can you measure it the same way fully extended again for me please?
Thanks!!!
Sat Dec 26, 2015 3:57 pm
Images: 14
Sat Dec 26, 2015 3:59 pm
About 32.5" with about 1" of spline engagement.
Sat Dec 26, 2015 4:09 pm
Images: 14
Thanks!!!
Looks like I might need to go the shop route and have them lengthen mine! Dang it!
Sat Dec 26, 2015 4:34 pm
Images: 14
The Driveshaft shop here in Greeley wants over $260 to add a couple inches to my stock driveshaft! I've found a couple of gently used Tom Woods DS's for $250 but I don't want to spend that much 'cause I'm cheap.
I will measure tonight but I assume that my stock Rear slip yoke measures 7". JBG and maybe others, offer a 9" long slip yoke for $40 bucks. I will probably end up going this route BUT...
OK Boys, just thinking out of the box here and I'm sure that there is a good reason for not doing it this way but l just Gots-ta-aks!!!
***What if I put a second CV joint at the rear end side. So 1 CV at the transfer case on top (stock setup), and added another CV on the bottom end behind the stock slip yoke???
This would give me the added length I'm looking for(too easy-knock it off), AND it would effectively cut my pinion angle in half!!! Brilliant!!! Right!!!???
...OK, I give you permission to crush my hopes and dreams :)
Tue Jan 12, 2016 10:56 am
Tue Jan 12, 2016 11:26 am
Tue Jan 12, 2016 12:06 pm
Images: 14
HA! LOL!!!
http://drivetrainindustries.com/ Jamie quoted me $250-300!!! and they take it down to Denver to do it.
Tue Jan 12, 2016 12:30 pm
Jeremy (casadejohnson) mentioned he had a shop in Greeley that was good. You might ask him.
Tue Jan 12, 2016 1:24 pm
Images: 14
Yahtzee!!!!!!!!
Tue Jan 12, 2016 8:18 pm
Front Range Driveline they do wonderful work they did the front and rear on mine and I like them very much.
there off of oxford and Federal
Tue Jan 12, 2016 9:28 pm
I use front range for several sets including two 1350's from scratch. They are good but not the cheapest.
Call and talk to bill he will give you a quote over the phone.
Wed Jan 13, 2016 2:29 pm
Not close but Bill's in Englewood rebuilt the rear for BSD, I've yet to break it.
Wed Jan 13, 2016 2:31 pm
I stopped by bills recently and was impressed. They'll be doing my driveshaft when I get it lengthened.
Wed Jan 13, 2016 7:54 pm
Images: 14
I will keep him in mind, but for now I'm going Frankenstein.
Double, Double Cardan!
...to be continued...
Thu Jan 14, 2016 12:12 am
I'm interested to see how this turns out for you. I would like something to help my rear angles...
But at $454, it's a big gamble!
Thu Jan 14, 2016 2:58 am
I don't like the double idea for an axle without a wrap trap of sorts.
Thu Jan 14, 2016 6:43 am
Thu Jan 14, 2016 8:21 am
Thu Jan 14, 2016 9:37 am
What JM said. I'm not seeing that a double cardan would affect wrap. Thoughts?
Thu Jan 14, 2016 4:20 pm
It won't cause axle wrap, but I wouldn't recommend it unless you had 10"s of lift and a low pinion axle. There's no need for anything more than a standard double cardan on a Bronco all the way to 5.5" lift. A double cardan is a weak point, no need to add another.
Thu Jan 14, 2016 7:23 pm
Im not saying it will cause axle wrap. But if you have any wrap I can see those CV's not playing nice. I just dont like the idea at all. Do it correct the first time.
Thu Jan 14, 2016 8:42 pm
Images: 14
Boyz, I'm not going to be doing Any Heavy wheeling! Maybe 62mph on the HW.
The only reason I even thought about this idea was to add a little length to my stock driveshaft. It does accomplish my original goal.
I didn't want to buy a used Tom Woods correct length for $250, and I'm certainly not going to fork over $400 plus!
I did however just purchase a used stock rear driveshaft ($25) with a CV joint on it that I am going to attach to my rear yoke.
4x$9.99 for new U-joints and voilà!
Mission accomplished. I lengthened my driveshaft, I decreased my pinion angle, and I didn't break the bank!
$65 bucks OTD!
Fri Jan 15, 2016 12:23 am
In my situation, I've got some lift, with a clocked-flat Atlas, which decreases the length of shaft while increasing it's angle. I'm not trying to call anyone out, but thinking thru the physics of this, I don't see how this would be any worse than a standard driveshaft.
I certainly don't like the price, but i could be a viable solution.
Wasn't RCV working on bringing driveshafts to market?
Fri Jan 15, 2016 5:27 am
Images: 14
I've been stretching lately, trying to be more flexible.
See, look... I'm almost Double Jointed :laughing2:
Tue Jan 19, 2016 9:42 pm
Users browsing this forum: No registered users and 51 guests
32,963,240 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
